Sony kv-21JDR1/S Retrace line only
Page 2 of 2 Previous  1, 2
Re: Sony kv-21JDR1/S Retrace line only
Post by kaholito on Sat Sep 14, 2013 6:17 pm
Ang tanong ko po pano magkakaro on ng 2vvolts sa rgb ng jungle IC.may sound nman po sya.duda ko jungle kaya lng wla po ako pang testing.hirap din mag tanggal ng jungle.
Post by kaholito on Sat Sep 14, 2013 6:18 pm
Sa jungle IC po ba naggagaling ang supply into na 2volts.
Post by arkin on Sat Sep 14, 2013 8:42 pm
try mo kyang maghanap ng c board w\ the same model.plit mode muna.mahirap tlaga yan sa sony:sasafsafgdsag:
Post by DJFEL on Sun Sep 15, 2013 9:09 am
ok kaya supply galing FBT...
Post by DJFEL on Sun Sep 15, 2013 9:10 am
na chik mo ba yong ABL neto..
Post by kaholito on Thu Sep 26, 2013 3:00 pm
Ok po ang abl into.may nkita po akong red blue green line sa taas ng tv screen.kita sya pag gabi sa araw maliwanag di sya makita.try ko na rin Ito plaitan ng working CRT board ala pa din.kaya sa jungle ako mag susunod ngaun.ano po mga voltage kailangang hanapin?
Post by arkin on Fri Sep 27, 2013 11:06 am
kong my rgb linings,indication yan of a faulty vertical circuit.chek vertical ecaps..
Post by Ahmadiloz on Fri Sep 27, 2013 5:02 pm
agree ako ky sir arkin......
suyorin mo muna Vert circuit...
usually may leak ung ecaps jan...
Ahmadiloz
Post by Hertz on Fri Sep 27, 2013 6:54 pm
puede din maka pag cause ang 9v supply dyan
Post by Oscar on Tue Oct 01, 2013 5:50 pm
master baka po mababa ang g2. taasan niyo master
