sharp 14v-s100
sharp 14v-s100
Post by arniemariano on Tue May 21, 2013 7:45 pm
bumabagsak po yung supply? pano i-check yung c2023? at a1013?
arniemariano
Re: sharp 14v-s100
Post by arkin on Tue May 21, 2013 11:10 pm
bakit klangan pa mgreplace,common sa market nyan.ingat lng sa c2023,maraming low qaulity na ngkalat.compare mbuti sa original one.magkano lng nasukat mo,at san mo sinukat?pag sa out,talagang zero yan on standby mode.common trasistor lng mga yan,kya sop na lng.
Re: sharp 14v-s100
Post by arniemariano on Wed May 22, 2013 12:15 am
pano po gagawin ko? bumabagsak po kasi yung supply kapag nililipat ko yung channel at kapag bagong bukas ung t.v.
thank you po
arniemariano
Re: sharp 14v-s100
Post by baddypepito on Wed May 22, 2013 8:01 am
check po maigi sa psu side. lalo na sa primary side. or it could be a leak ecaps or change value resistor.
surely nasa psu ang problem nito sis. visual check mo at tester mo.
Re: sharp 14v-s100
Post by arniemariano on Wed May 22, 2013 12:02 pm
ok po. sundin ko po payo nyo. maraming maraming salamat po. i tell you po kapag ok na.
arniemariano
Re: sharp 14v-s100
Post by arniemariano on Wed May 22, 2013 12:03 pm
kumukundap-kundap po sya pa-vertical line eh
arniemariano
Re: sharp 14v-s100
Post by ultrasonic™ on Wed May 22, 2013 12:40 pm
agreed.. common available locally yan sa market
btw baka mkatulong itong mapa
http://aelexian.4rumer.com/t595-sharp-cinemaborg-schem..
Re: sharp 14v-s100
Post by ultrasonic™ on Wed May 22, 2013 12:43 pm
kng vertical line from top to buttom ang lines ay nasa horiz sect nga yan or psu...
na try mo na ts sa 110V source ang unit mo?
Re: sharp 14v-s100
Post by arkin on Thu May 23, 2013 8:42 pm
nko,flybak problem yan.pro mkukuha yan sa modification ng ABL resistors.taasan lng ng pakonte-konte yong value nto.kong baga,trailang error method.tignan mo nlng sa diagram,dlawang nkaparalel resistor yan.sori at nkalimotan kna yon value,prang nsa mga 100k ata yon.
Re: sharp 14v-s100
Post by arkin on Thu May 23, 2013 8:44 pm
my mali sa post ko Very Happy trial and error method yon.
Re: sharp 14v-s100
Post by ultrasonic™ on Fri May 24, 2013 6:14 pm
^ pwde...
change value ABL resist (r455 & r456) 220k
Re: sharp 14v-s100
Post by DJFEL on Thu May 30, 2013 9:00 am
na sa giled nang FBT yong risistor...pake chik..open yata yan..
Re: sharp 14v-s100
Post by arkin on Fri May 31, 2013 2:26 pm
DJFEL wrote:na sa giled nang FBT yong risistor...pake chik..open yata yan..
for sure,hindi open yon.black screen with OSD ang mkikita mo sa screen pag open yon. Very Happy
Re: sharp 14v-s100
Post by DJFEL on Fri May 31, 2013 8:16 pm
abang nalang..
Re: sharp 14v-s100
Post by arniemariano on Sat Jun 01, 2013 1:44 pm
ok na po yung unit, stable na sya. maraming salamat po sa mga tulong nyo. thank you so very very much talaga
arniemariano
Re: sharp 14v-s100
Post by bjohn7908 on Sat Jun 01, 2013 11:02 pm
pa share po what are the solution to the problem? hehe
bjohn7908
Re: sharp 14v-s100
Post by DJFEL on Sun Jun 02, 2013 2:59 pm
arniemariano wrote:ok na po yung unit, stable na sya. maraming salamat po sa mga tulong nyo. thank you so very very much talaga
ano trouble..
Re: sharp 14v-s100
Post by arniemariano on Wed Jun 05, 2013 11:59 pm
stk po mga master. pinalitan ko po sya then ok na po. kaso ung nabibili ngayon na stk is hindi nagtatagal kapag naka 220v dapat po 110v lang.
arniemariano
Re: sharp 14v-s100
Post by baddypepito on Thu Jun 06, 2013 7:48 am
baka fake yan..
Re: sharp 14v-s100
Post by arkin on Thu Jun 06, 2013 12:11 pm
mga ilang minutes lng itinagal ng stk?kong d umabot ng 5 minutes,tyak ang dating problema mo ang nagpabagsak sa stk mo.take note:magkakaron ng heavy load ang regulator circuit sa ganong problema.hanap ka ulit ng stk,at abang mode nlang kmi.
Re: sharp 14v-s100
Post by ultrasonic™ on Thu Jun 06, 2013 12:39 pm
nko sakit tlga sa ulo yang stk73907 dhil na rin sa fake na ngkalat...
agreed ky sis arkin.. double check na rin ng mga peripheral parts
Re: sharp 14v-s100
