Sinu po may 25L8005 eeprom programmer?
Post by zandertech on Tue May 07, 2013 10:57 pm
Cnu po may programmer/flasher ng mx25L8005? Bka pwede po pa program mga boss bayad nlng po ako nid ko lng for my laptop,corrupted po kc ,papa shipping ko nlng po maraming thenk u' sa makakatulong in advance,.o kya po kung mer0n kay0n i.c. N ganyan bilin ko nlng eeprom ng HP laptop po yan,
Re: Sinu po may 25L8005 eeprom programmer?
Post by zandertech on Tue May 07, 2013 11:00 pm
Sa mer0n po message me on fb,.zander_1959@yahoo.com thanx a lot,.looking 4ward for your help mga boss,.
Post by MCU on Wed May 08, 2013 5:42 pm
you can use SPI Flash programmer. look ultra's post on technician board. you can build with your own or just tried this upgraded version
download project
IC1 : 8 Pin Machine Tooled IC Socket
IC2: 74LS244
IC3 : 78M05 Positive Voltage Regulator
R1,R2,R4,R5,R6,R7 : 33R 1/4W Resistor
R3,R8,R9 : 10K 1/4W Resistor
D1,D2,D3 : 1N4148 Diode
D4 : 1N4001 Diode
C1,C2 : 100n Capacitor
C3 : 100uF Electrolytic Capacitor
X1 : DB25 PCB Mount Male Connector
This programmer supports: ST Micro M25(E), ST Micro M45(E), Macronix MX25L, Atmel AT25FS, Atmel AT25DF, Atmel AT25F, Amic A25LxxP, Amic A25Lxxx, Eon EN25(B/D/F/P) read only, Winbond W25X, Winbond W25Q (OTP), SST SST25(LV/VF)xx, SST SST25VFxxxB, Spansion S25FL and ESMT F25L.
you can read more on teknikservice.net
- mcu -
MCU
http://aelexian.4rumer.com
Post by ultrasonic™ on Thu May 09, 2013 2:29 pm
oh my... affraid
almost pareho nga cla ng DIY SPI programmer ni sis noman....
pareho din ang GUI
pnagkaiba lng ay dinagdagan ng buffer/line driver ic..
sir m... tnx sa pgshare nito.. mas mbilis cguro to mgprocess... gusto kng sbukan.. sali ko to next projz ko (^_^ jejejeje +1
@sis zander,,, meron ka bang data pangload sa mx25L8005 na tugma sa lappy mo?
Post by james on Thu May 09, 2013 4:19 pm
Para saan ba yan ginagamit mga sir?
Post by ultrasonic™ on Thu May 09, 2013 5:01 pm
pang program yan ng memory chip sis...
Post by zandertech on Thu May 09, 2013 11:44 pm
ui thank you very much mga bossing malking tulong po ito skin,.mhahalikan ko kayo heheh Smile
Post by zandertech on Thu May 09, 2013 11:49 pm
san po makukuha ung app. interface mga boss ,. thank you ulet boss mcu at ultra meron na pla ko program boss ultra nid ko nlng programmer Smile
Post by zandertech on Thu May 09, 2013 11:52 pm
pwede po kya i program kahit corrupted n ung ic ?
Post by ultrasonic™ on Fri May 10, 2013 1:31 pm
^ AFAIK, as long nadedetect pa ang memo chip sis at tumatanggap at nasesave pa ng data ay pwde pwde pa yan..
regarding sa GUI nsali na din sa attachment sis..
check mo nlng
Post by james on Fri May 10, 2013 2:16 pm
Kakatuwa naman mga kaalamang nakukuha dito. Very Happy
Post by zandertech on Fri May 10, 2013 2:57 pm
good news mga bossing nagawa ko na c laptop Smile thanks ng marami sa inyo Very Happy[img][/img]
Post by ultrasonic™ on Fri May 10, 2013 5:11 pm
zandertech wrote:good news mga bossing nagawa ko na c laptop Smile thanks ng marami sa inyo Very Happy[img][url=http://www.servimg.com/image_preview.php?i=12&u=16904307]
oie congratz kng ganun
+1 sa pagshare
Post by james on Sat May 11, 2013 7:00 pm
Pashare naman ng procedure sir kung apaano mo ginawa. Para matuto naman kaming nag-aaral pa lang.
Post by zandertech on Thu May 16, 2013 1:30 pm
bos james ginawa ko lng ung programmer diagram na binigay ni sir ultra,.un ung nsa pic ko nga lng inprovised lng heheh la kc ako parallel port connector kya gumawa nlng ako ng mga pins na tugma sa pinout ng parallel connector ng pc ko,.tapos gumamit lng ako ng usb cord para kumuha ng power sa mismong usb port ng pc then gumamit ako ng GUI n kasama sa attachment ni bos MCU,. and dinownload ko lng ung flash file ng laptop ko then flash it on eeprom ic 25L8005,.ginamit ko ung Eeprom na galing sa DVD na currupted na,.kc ayaw na magrespond ng EEprom na galing sa laptop ko sira na yata,..btw,when flashing i first selected my com port ,.then erase device,.after erase check if its empty,.then proceed to flashing select the firmware you will use,. select the eeprom family,. mine its 25L8***,then write,.wait till done,when done check if the device is empty,if succesful it will prompt that the device is not empty,.then youre done flashing,..after flashing its time to test the eeprom,.since mas malaki ung eeprom ng dvd saeeprom ng laptop ko e jinumper ko n lng just follow the pinouts,.refer to datasheet or just follow the marker of eeprom,.then done ,.[img][/img] ,.[img][/img]
Post by james on Thu May 16, 2013 4:42 pm
Ang galing naman. Teka yung bang ic magkaiba ng family?
Post by baddypepito on Thu May 16, 2013 5:17 pm
wow ang galing mo sis! shakehand
Post by ultrasonic™ on Fri May 17, 2013 8:09 pm
sis zander... pwde mo bang maepost anong site mo na DL ang dump ng lappy mo.. pangreference sana ng iba
if ok lng (^_^
Post by james on Mon May 20, 2013 6:35 pm
OO nga baka pwede malaman kung san galing.
Post by zandertech on Tue May 21, 2013 1:25 am
sa website boss ng HP meron sila don,. lahat yata ng laptop meron sa kani kanilang support website,.25L8XXX ung family ng ic ko sis james magkaiba lng ng maker,.umubra nmn ung galing sa Promac DVD Player,.ung ibang DVD kc 25T80 di ko lng alam kung pwede rin sila ,.bale eto ung Dump ng laptop ko,.http://www.4shared.com/file/_l3kbtr6/hp_presario_F35.html sya ung Firmware na naglalaman ng Bios,
Post by ultrasonic™ on Tue May 21, 2013 12:47 pm
tnx... +1 ulit
keep it up sis (^_^
Post by MCU on Tue Jul 09, 2013 11:28 am
 salamat sa puntos.
congrats kay zander
MCU
