SONY TRINITRON BLINKING PROBLEM HELP!!!!!!!!!!!
Post by batmantech on Sun Apr 28, 2013 1:30 pm
Pa help po about dito sa inaayus kung television SONY po ang brand dati po siyang 110v converted na po siya sa 220v. ang problem po nito pag inuon po walang picture as in black pero may supply po siya how do i say na may supply kasi po may ilaw po yung power indicator niya....nag biblink po siya ng four (4) times then a seconds blink ulit ng four (4).... san po kya problem nito ? pa help po asap
KV-25DA55 TV model
D2634 - HORIZONTAL
AN5522 -VERTICAL
1-683-275-13 -CHASSIS NUMBER
25 INCH po ito
Re: SONY TRINITRON BLINKING PROBLEM HELP!!!!!!!!!!!
Post by batmantech on Sun Apr 28, 2013 1:32 pm
by the way po nag iistore then po pla yung filter cap niya ng kuryente (680uf 160v) po siya in series po silang dalawa....check kuna po yung part ng power supplygood nman po siya san kya sira nito? doubt
Post by arkin on Sun Apr 28, 2013 9:34 pm
kong d ako nagkamali,4 blinks is indication of vertical section problem.fucos muna sa area na yan..
Post by batmantech on Sun Apr 28, 2013 11:14 pm
eh 110v ang supply niya convert lang sa 220v vertical pa din bayan?
Post by baddypepito on Tue Apr 30, 2013 12:08 am
check vertical section
Post by ultrasonic™ on Tue Apr 30, 2013 1:36 pm
my resistor bato nkaseries from B+ line to vertical..
try mo idisable sis
Post by batmantech on Thu May 02, 2013 9:20 am
sori for late post kuha kuna po yung sira pinalitan ko mismo po ng jungle ic yu naayus na po...pero i try din po yung mga suggestion niyo pero i got the troubles from the jungle ic it self thanks guys
Post by ultrasonic™ on Thu May 02, 2013 12:33 pm
ayos na pala. congratz
Post by james on Thu May 02, 2013 3:05 pm
Congrats.
Post by baddypepito on Sat May 04, 2013 10:29 pm
ganun ba... mg4 blinks ba kung sira talaga ang jungle? anyways,,,, congrats!
Post by DJFEL on Thu May 30, 2013 9:15 am
hmm..parang nasa vertical section ang probs dyan...piro nakoha pala sa jungle..sapol na pala..
