help PANA TC-20P1N No B+
Post by Deantyne on Sun Mar 31, 2013 4:50 pm
pa help po sa panasonic tv:
MODEL: TC-20P1N
trouble : NO B+
STAND BY POWER ONLY,
NO CLICK, NO REACTION ON RELAY WHEN SWITCH TO POWER ON
DONE:
relay no clicking: with 24volts on coil side (RL801)
No Collector voltage on HOT D2499 (Q566)
w/ collector voltage on Q801-C5253 (main power xsistor) around 300v ,no voltage on B/E
No voltage on D892 - RM25 (R2M) B+
C808- NO VOLTAGE B+ (220UF/200VDC)
baka po may magandang loob na mag-share ng mapa nito? litong-lito na kasi ako.
Maraming Salamat Cool
Deantyne
Re: help PANA TC-20P1N No B+
Post by baddypepito on Sun Mar 31, 2013 9:20 pm
focus po muna sis sa power supply, baka may open na resistor.... mostly in kiloohms value. seems to be problematic pa ang psu mo.
Post by Hertz on Sun Mar 31, 2013 11:28 pm
hindi ba ito iyong hanap mo?
PAnasonic tnp4g036at
Post by Electro on Mon Apr 01, 2013 1:00 pm
tama si master baddy baka po may open na resistor
Post by DJFEL on Mon Apr 01, 2013 3:24 pm
yosod mona sa secondary supply..
Post by ultrasonic™ on Mon Apr 01, 2013 3:41 pm
AFAIR ndi yata yan hertz.. PX1 chassis e2.. etot sinsearch ko sa baol kng naitago ko ba ang mga luma kng diag nyan para ma escan natin...
do the basic nlng muna sis deantyne. pwde nga yang open resist o tranny
Post by Deantyne on Mon Apr 01, 2013 7:50 pm
maraming salamat po mga masters..
susuyurin ko muna to..
keep updated..
Deantyne
Post by Hertz on Sat Apr 06, 2013 11:24 am
sorry px1 pala.
Post by Deantyne on Tue Apr 09, 2013 7:13 am
up...
check ko lahat ng resistor sa power supply section but no luck, no one found defective.
trannies malapit sa relay ok rin..
nang-i temporary short ko yong relay, gumana na ang power supply. baka kaya may tama na ang system ic nito?
ito ang system ic = MN1873265T8K
JUNGLE IC= AN5192NK
baka meron kayong exact pinning ng system ic? or exact mapa..
maraming salamat po ulit..
Deantyne
Post by ultrasonic™ on Wed Apr 10, 2013 1:14 pm
kainis.di ko tlga ma DL ang mga PX series... binablock nko ng mga taga pana.. (T_T sis deantyne my 5v supply ka ba sa system con?
umaabot ba sa mga tacts sw? pwde pamalit ang MN1873265TB2, MN1873265TZ1 at MN1873265TD0
Post by Deantyne on Sat May 04, 2013 10:34 pm
Sis, meron ka jungle ic available?kahit bunot basta ok-no problem.. pa-pm.. thanks,
Deantyne
Post by ultrasonic™ on Mon May 06, 2013 10:54 am
sori nows lng nkabalik.. feedback ako sau bukas.. tignan ko muna sa baol kng my naitabi pa kong ganyan
Post by ultrasonic™ on Tue May 07, 2013 2:28 pm
nko sis..sad to say, ubos na din pala ang spare ko nyan.. (T_T
mga AN5160NK nlng ang natira na pang pana sakin... ang mhirap nyan sis faceout na yang 5192NK dito sa davao.. kng meron mang nagbibinta tiyak nasa 1.8K ang isa nyan.. wait na rin tau bka my naitabi ang iba
Post by Deantyne on Sat May 11, 2013 9:40 pm
ultrasonic™ wrote:nko sis..sad to say, ubos na din pala ang spare ko nyan.. (T_T
Salamat sis...
wait na lang ako sa update, sigurado na itong system ang sira kasi walang 5volts..
Deantyne
Post by Deantyne on Sat May 11, 2013 9:44 pm
sis ultra paano nga pala ang plus pogi points dito?
+1 sa yo
Deantyne
Post by ultrasonic™ on Tue May 14, 2013 12:54 pm
nasa right side ng mga post natin sis (^_^
Post by Deantyne on Tue May 14, 2013 10:33 pm
159+1 ..maraming salamat Very Happy
Deantyne
Post by ultrasonic™ on Wed May 15, 2013 7:17 pm
ngeee binigyan pa ko ng point (^_^
+1 din sau sis
Post by Deantyne on Wed May 15, 2013 7:33 pm
ultrasonic™ wrote: MN1873265TD0
Sis, matanong ko lang.. pinalitan ko ng MN1873265TD0 umandar na, pero vertical one line ang raster.. replaced already vertical ic and suyod lahat ng peripherals pero ganon pa rin.. posible bang di sila match? kasi itong pinalit ko, bunot lang din sa ibang board, di rin sure nagpahiram sa akin if totally good ito..
Deantyne
Post by ultrasonic™ on Thu May 16, 2013 1:22 pm
^ hhmmmppfff based dito sa notes ko sis.. .they are comptible meron pa nga ditong isa na MN1873265T8K
teka lng, buo ba lhat ng supply ng vert drive nya sis at ok ung pin 13 ba un o pin 1 na laging na napapashort natin minsan na di sinasadya
