Sanyo TV start-up problem
Post by Lenaren on Mon Mar 18, 2013 8:30 am
Masters... tanong lang po kung ano problem ng TV pagka-ON medyo delay ang display nya?...
Re: Sanyo TV start-up problem
Post by ultrasonic™ on Mon Mar 18, 2013 11:02 am
anong klaseng pgkakadelay?
kng sa video bka kapos kau sa video supply (180V) sa C board its better to change the filter ecaps xxuf/160v
or pwde din corroded ang cpt socket
Post by Lenaren on Mon Mar 18, 2013 2:49 pm
Pagka-ON ng unit ilang seconds pa bago magka-raster.... bagong palit po master ung filter ecaps.... Try ko mamaya voltage check...
Post by baddypepito on Mon Mar 18, 2013 10:47 pm
pwede din sis na picturan mo o kaya video nang magiging malinaw at madaling matrace kung anong section ang may problema
Post by Lenaren on Tue Mar 19, 2013 1:07 pm
....noted mga sis....
Post by ultrasonic™ on Wed Mar 20, 2013 5:07 pm
try na rin na jumperan ng wire ang current limiter resistor ng heater supply mo... pang prove lng bka mgkakaroon ng improvement
Post by Lenaren on Thu Mar 21, 2013 1:09 pm
Update lang.... Sa ngayon master OK na ulit ang TV... wala pa akong ginalaw... sinubukan ko lang ulit na i-ON... ayun naging OK... obserbahan ko na lang muna to and check for loose con....
Post by DJFEL on Fri Mar 22, 2013 10:25 am
parang losecon yata sa supply ha galing nang B+ supply...
or yong c-bord probs or mga sakit neto..
Post by Hertz on Sun Mar 24, 2013 10:25 pm
congrats baka loose contact lang
Post by ultrasonic™ on Wed Mar 27, 2013 3:58 pm
agree mukhang loose con lng cguro to..
congratz sis (^_^
Post by Lenaren on Wed Mar 27, 2013 11:12 pm
So far until now OK pa rin ung TV... Salamat!!!
Post by DJFEL on Fri Mar 29, 2013 9:16 am
okis na yan...Smile
Post by Lenaren on Sat Apr 13, 2013 10:03 am
Master tulong ulit... nagkaproblema ulit ung unit...
Pagka-ON walang sound at display pero pag tinaasan ko ung screen voltage... nagkaka-display sya pero may retrace lines tapos ung screen lumiit... mga 3 inches ang bawas sa taas at baba...
Napansin ko rin master pag-iplug ko ang unit na sa na naka-ON na ang switch ng ilang beses... naging normal ang display nya.. kaso pag pinatay u ulit ung unit wala na namang display.... gagawin u na naman ulit ang nasa taas..
Ano master problem nito? Salamat
(from normal display pag-iOFF u ang unit may mga horizontal na guhit kang makikita)
Post by ultrasonic™ on Sat Apr 13, 2013 10:29 am
pwde my probz ang PSU mo sis.. ano ang reg nito? ano ang model?
Post by Lenaren on Sat Apr 13, 2013 11:04 am
STR-W6753 master.... 21CE1... AC6A1 chassis...
Minsan naman may sound pero walang display....
Post by ultrasonic™ on Mon Apr 15, 2013 11:59 am
^ my pmalit ka ba nyan sis? try mo lng...
try na rin e e unsolder ang UOC at at linis mode.. at kabit ulit..
pwde din sa eeprom to.. lalot kng corroded ang mga tact's
Post by Lenaren on Tue Apr 16, 2013 7:25 pm
sinubukan ko master pero wala pa rin...
ngayon meron syang display pero maliit.... kulay green with retrace lines.... kaso pagkatapos ng ilang minuto namamatay agad...
Pahirapan na naman nito!!! scratch
Post by ultrasonic™ on Tue Apr 16, 2013 7:45 pm
mukhang knakapos ka nga sa supply. . direct sub ka muna.. sali na rin ang ecaps sa B+ at video supply
Post by Lenaren on Tue Apr 16, 2013 11:48 pm
try ko na lang palitan ung video caps... bago na kasi reg at ecap ng b+... thanks
Post by Lenaren on Mon Jul 29, 2013 11:17 pm
Update ko lang... OK n to.. forgot to update... tagal na nito... problem nito may open na diode sa ABL circuit... Salamat
Post by triac on Tue Jul 30, 2013 9:53 am
congrtaz sis lemaren..congratulations
Post by ultrasonic™ on Tue Jul 30, 2013 4:35 pm
protect pala to  (^_^
Post by Electro on Fri Aug 16, 2013 4:39 pm
congrats at +1 master Lenaren. laki tulong nito samin
