flash drive.-write protected error-
Post by 2resjery on Wed Feb 20, 2013 11:28 am
mga master patulong naman,, hindi q na kasi ma format ang flashdrive na 2...na dedetect pa naman sya ng computer, nakikita ko pa ang mga files na naka stored, pero hindi aq maka pag delete or maka dag.dag ng kahit anung files,,,kasi naka write protected sya....panu kaya 2 mga sir?..tnx.
2resjery
Re: flash drive.-write protected error-
Post by Lenaren on Thu Feb 21, 2013 10:11 pm
Ano ba hitsura ng flash drive nyo? Kung memory card at ginagamitan u ng card reader at adaptor kelangan u muna i-unlock. Check u ung gilid ng adaptor nyo.... may switch jan...
Post by Digitap on Fri Feb 22, 2013 12:58 pm
wala na bang valuable files kuya? nasubukan mo na ba kuya sa DOS mode?
Open a DOS command window:
1.Start>run and type cmd then click 'OK'
2.Type: format <drive>: where <drive> is the drive letter assigned to the memory stick shown in Windows Explorer.
3.At message: "Insert new disk ....." press 'Enter' key.
4. At message "Format cannot run because volume is in use ........ would you like to force a dismount on this volume? <Y/N>" press the 'Y' key.
USB devise will then be reformatted and usable in Windows XP & 7
NOTE: ALL DATA ON THE USB DEVICE WILL BE DELETED.
pwede din subukan sa diskmanagement
Go to run type diskmgmt.msc
Right click your usb
Then choose format
Then choose fat32
Then hit ok
Wait for 100%
pag ayaw niyang pumayag
subukan niyo naman sa regedit
in Run command type regedit
then goto:
1:HKEY_LOCAL_MACHINE\
2:SYSTEM\
3:CurrentControlSet\
4:Control\
5:storagedevicepolicies
then go on write protection on the storagedevicepolicies.
double click on write protection and change the hexadecimal value to 0.
if storagedevicepolicies is not found then single click on control and goto edit of toolbar
then goto New and then key
write the key name as storage device policies
then a new folder named storagedevicepolicies is created
click on storagedevicepolicies and
HOPE YOU HAVE DONE IT
Then Try to format your Write Protected usb Drive IT might Work..
if none i think you need a software Repair tool
Post by ultrasonic™ on Wed Feb 27, 2013 7:14 pm
waaa... daming mong pang backdoor princess (^_^
+1 mgagamit ko yan sa susunod
@jery try mu na rin sa h2testw bka kakayanin
Post by james on Thu Feb 28, 2013 3:20 pm
Hindi yan gagana princess.
Post by ultrasonic™ on Fri Mar 01, 2013 7:04 pm
affraid what? totoo ba yan sis?
no idea & no comment muna ako.. Banana dancing di ko pa kasi nkakasubok ang ganyang procedure.. susubukan ko pa lng... (^_^
hope my mligaw na fd dito
Post by james on Sat Mar 02, 2013 3:19 pm
Sis ba tawagan dito? Para kasing napapansin ko yan lagi ang tawag ni sir admin.
Post by dodongleo on Tue Mar 05, 2013 4:05 pm
yup sis james Very Happy
dodongleo
Post by Digitap on Tue Mar 05, 2013 4:48 pm
james wrote:Hindi yan gagana princess.
gagana po yan kuya. i know na di sa lahat ng usb stick. pero pinasusubok ko lang naman, wala rin namang mawawala or else other alternative way ang dapat na nating gawin
Post by james on Wed Mar 06, 2013 8:43 pm
Aw totoo nga sis ang tawagan.
At iyan princess ay bumili ba ng bago?
Post by Digitap on Wed Mar 13, 2013 11:49 am
No, i dont say that kuya pale maybe if the hardware chip is damage.
meron akong iilang ufd tool pang repair
http://www.4shared.com/rar/UoQ1nzAG/usbfdtool_part1.html
http://www.4shared.com/rar/-bYqdMTT/For_Write-Protected.html
few brand lang ang supported pero kong genuine ang fd niyo. subukan niyo na lang bisitahin ang mga supporting website nila. may free ufd repair tool naman binibigay ang mga ito just like you are updating a drivers on your computer.
Post by Lenaren on Wed Mar 13, 2013 1:51 pm
Salamat sa pag-share nito sis... 1+ for you...
Post by james on Wed Mar 13, 2013 8:38 pm
Salamat princess
Post by ultrasonic™ on Fri Mar 15, 2013 1:58 pm
ano passcode nyan princess? di ko mbuksan (T_T
Post by james on Sat Mar 16, 2013 5:16 pm
passcode di namin nabuksan bb princess
Post by ultrasonic™ on Sat Mar 16, 2013 5:54 pm
kala ko ako lang hahahaha lol! Banana dancing
Post by Digitap on Sun Mar 17, 2013 11:44 pm
waiting nick name ko
Post by ultrasonic™ on Mon Mar 18, 2013 12:22 pm
ayon na open ko na.. tnx +1 princess
Post by james on Mon Mar 18, 2013 2:15 pm
ano ba nickname mo princess?
Post by FANY MOHANDES on Mon Mar 18, 2013 4:07 pm
ma'am Princess pde po bang malaman ung passcode ndi po kc mabuksan. thanks ma'am Princess.
FANY MOHANDES
Post by FANY MOHANDES on Tue Mar 19, 2013 4:09 pm
Ma'am princess pde po malaman ano ung nickname nyo pasensiya na po.
FANY MOHANDES
Post by ultrasonic™ on Tue Mar 19, 2013 10:46 pm
ako nlng ang ssagot.. (^_^
wla pa rin prensesa
username niya mga sis ang passcode
Post by FANY MOHANDES on Wed Mar 20, 2013 4:07 pm
Maraming salamat master Ultra. Master ask ko lang pano ba magbigay ng points dito? pde din ba kong magbigay ng points?
FANY MOHANDES
Post by ultrasonic™ on Wed Mar 20, 2013 5:04 pm
uu nmn.. my mkikita kang + sign sa right side ng pgbibigyan mo
Post by Digitap on Fri Mar 29, 2013 4:29 pm
Your welcome. Razz
