pa help ulit mga master AIWA nman!!!!!!
Post by batmantech on Mon Feb 18, 2013 3:14 pm
aiwa tv model tv14gt11 11ov po ang supply nito......... ang problem naging black and white po siya tska cloudy yung screen may mga picture po aq nitong tv na to
yan po yung image niya san po ba posible cause and problem nito hel po asap...
Re: pa help ulit mga master AIWA nman!!!!!!
Post by ultrasonic™ on Mon Feb 18, 2013 5:34 pm
my AV mode ba to?
kng meron.. same lng ba ang behavior ng display?
meron din ba tong service sw.?
subukan din ilipat lipat..
di ko masxadong maaninag ang image..
pero kng cloudy eto at B&W bka tuner hanggang comb filter ang my problema
Post by batmantech on Mon Feb 18, 2013 9:15 pm
tnx po master ultrasonic ill just post nalang yung next update ko bukaas
Post by batmantech on Tue Feb 19, 2013 10:38 am
san po makuikita ang comb filrter?
Post by ultrasonic™ on Tue Feb 19, 2013 6:58 pm
between tuner to jungle.. or pwde din nkabuild na mismo sa jungle.. ano ba ang part number nyan? nang mtignan natin sa datasheet at ska pkisagot ng mga tanong ko sa taas
Post by batmantech on Tue Feb 19, 2013 8:21 pm
my AV mode ba to? meron po yata ano po pala yung AV mode?
meron din ba tong service sw.? ano pong service switch kung yung sinasabi niyongswitch pag inu on yunbg tv isa lang po at tackle switch po yun
din ano po yung configuration ng comb filter? may picture ka po ba nito? di ko po mahanap yung comb filter eh help po pls......
eto pa po yung image na malinaw ng kunti
http://s1283.beta.photobucket.com/user/Romnick_Dela_Cruz/media/Img00371_zps75bd5c6d.jpg.html
doubt
Post by baddypepito on Wed Feb 20, 2013 8:58 am
parang overbright yan. check po ang mga trimmer jan. at sa mga ecaps narin.. baka my nakasulat jan na brightness sa my trimmer.
Post by batmantech on Wed Feb 20, 2013 3:10 pm
s brightness po yung naka sulat check kuna po kya lang good po eto
Post by batmantech on Thu Feb 21, 2013 10:45 am
asan na po kayu help nman po pls...
Post by Electro on Thu Feb 21, 2013 11:52 am
master batman av - audio video na siya master. para makapanood ng dvd. satingin ko master may open resitor kayo
Post by batmantech on Thu Feb 21, 2013 6:59 pm
kuha kuna sira niya jjejje tnx a lot mga master 3 araw ko e2ng sinuyod pinalitan ko ng tuner ayun ayus na !!!!tsak may open nga resistor malapit sa jungle ic niya yun ayus na yung kuly pati pag nag papanuod ng dvd ayus na rin tnx mga master............ Smile +1
Post by ultrasonic™ on Mon Feb 25, 2013 1:25 pm
nko nahuli nko sa update dito..
congratz sis +1 sau for updating the thread
eto pala ang appearance
nasa sub brightness, sub contrast at sub color adj. nga ang probz nyan.. lalot kng both av mode & tuner mode.. kng dE pihit pa ang unit mo "trimmer" or known as service sw (preset)..
laging salarin ang trimmer or resistor na nkahilira nito.. its either open or change value..
BTW kaya pinapacompare ko sau sis ang 2 modes ng set mo para mlaman mo agad saan ka babanat.. halimbawa kng sa tuner mode lng ang ganyang dispaly suspect mo jan ay tuner module hanggang comb filter, saw filter, IFT's.. so at least ma leleast mo ang suspect na di na isasali ang mga preset adj.
Post by DJFEL on Tue Feb 26, 2013 11:14 am
batmantech wrote:kuha kuna sira niya jjejje tnx a lot mga master 3 araw ko e2ng sinuyod pinalitan ko ng tuner ayun ayus na !!!!tsak may open nga resistor malapit sa jungle ic niya yun ayus na yung kuly pati pag nag papanuod ng dvd ayus na rin tnx mga master............ Smile +1
ayos na pala to...
