AC Adapter Power Charger&US Cord for HP/Compaq 463552-004 608425-001 613152-001
Post by DJFEL on Wed Jan 09, 2013 3:51 pm
pa help...ano function neto..my pin sa elalim my 3wire..wlang power eto..my nka trouble na ba dito..
Re: AC Adapter Power Charger&US Cord for HP/Compaq 463552-004 608425-001 613152-001
Post by ultrasonic™ on Wed Jan 09, 2013 6:05 pm
sa mga naeencounter ko nyan sis, mostly shorted o open ang dulo ng wire output..
o di kya shorted ang power mosfet at busted ang fuse sa loob...
kng mamalasin sira din ang pwm ic (^_^
Post by james on Wed Jan 09, 2013 8:51 pm
Anong may 3 wire? Baka naman yung equipment ground?
Abuse sa chord yan dulo dulo napuputol ang wire.
Post by DJFEL on Thu Jan 10, 2013 11:54 am
james wrote:Anong may 3 wire? Baka naman yung equipment ground?
ok lang yong wire...chik ko mona tong fusible..
Post by DJFEL on Thu Jan 10, 2013 11:56 am
pang ganon bile nalang bago..weeeee
Post by DJFEL on Thu Jan 10, 2013 12:09 pm
trouble mona...baka ma ok pa to..
Post by james on Thu Jan 10, 2013 1:16 pm
Mas simple talaga design ng mga sinauna.
Anong mga IC sir?
Post by DJFEL on Thu Jan 10, 2013 2:49 pm
ano # kaya to...
SIPS20S100C wlang datasheet..
Post by ultrasonic™ on Thu Jan 10, 2013 3:29 pm
saang parte yan sis? Reg ba iyan ng HOT side o COld side?
kng sa HOT side.. mostly Mosfet iyan.. kng sa Cold side /secondary bka dual diode lng iyan (^_^
Post by DJFEL on Fri Jan 11, 2013 12:39 pm
secondary sis...hinde ko ma kita sa datasheet...diode 2..wlang ako ma test..parang sira ang primary neto..
Post by james on Fri Jan 11, 2013 4:10 pm
Kapag secondary malamang two diode yan. Test mo maski isang junction sa gitna yung cathode nyan. Tapos sa tabi karaniwan yung anode.
Sa primary side FET.
Post by DJFEL on Thu Jan 24, 2013 4:26 pm
bile nalang bago...yong ic yong sira...hay nako...Sad
