help po sa HDD ko
help po sa HDD ko
Post by ton_allen on Sat Dec 22, 2012 7:35 pm
hi po sa lahat patulong po sa HDD ko external hard drive po... kasi lagi po sya nag cocorrupted kapag sasalpak ko sya sa pc... ano po ba magandang gawin? at merun po ba tricks or sulotion para hindi na sya mag cocorrupt?? ung mga files ko na uubos kasi no choise ako foformat ko sya uli para magamit.. Sad
ton_allen
Re: help po sa HDD ko
Post by ultrasonic™ on Wed Dec 26, 2012 1:05 pm
bka my problema ang cable or kapos sa supply
Post by james on Wed Dec 26, 2012 6:51 pm
Software dismount first before unplugging the usb.
Ikabit mo sa mahigpit na suksukan.
Palitan ng makapal na orig na cable.
Post by ultrasonic™ on Thu Dec 27, 2012 1:18 pm
agreed (^_^
Post by Lenaren on Fri Dec 28, 2012 8:00 pm
Ung cable ba na ginagamit u ung kasama ng unit (orig)? ... Na-try ko rin kasi sa aking external HDD pag ordinary USB cable lang nagloloko ung xHDD ko...
Post by arkin on Sat Dec 29, 2012 9:49 am
uncheck quick format option when formatting.diskcheck plagi..
Post by Digitap on Wed Jan 02, 2013 12:37 pm
pag ok ang cable at ok naman ang hard drive. baka sa supply nga iyan, subok mo sa ibang PC units na may mataas na Power wattage
Post by zandertech on Sun Jan 06, 2013 12:02 pm
sir try to update driver
Post by DJFEL on Thu Jan 10, 2013 11:59 am
chik yong wire sa ebang unet f sem pa rin..scan f my virus yan..
Post by fire on Fri Jan 18, 2013 2:22 pm
na try nyo n po ba isalpak sa ibang pc ang external hdd?pag gumana sa ibang pc it means sa computer mo po may prob.if ganun p rin sa iba try mo nmn scan if may virus sya use good antimalware and antivirus program for scanning for sure na mawala virus.try malwarebytes and avast....or use Hdd regenerator para ma scan ang hardisk mo...para malaman mo kng may bad section sya loob...i hope this help Rolling Eyes
fire
Post by DJFEL on Thu Jan 24, 2013 4:29 pm
ano apdit kaya nito..
