totally deadset
totally deadset
Post by jopaw on Wed Nov 28, 2012 11:08 am
sr mrn ako tv n kolin dead set, check voltage po ako so ung main trans former my input voltage nmn, pero wla po ko ma read n output voltage so binaklas ko ung transformer nung pagtester ko my palo nmn po so posible po b n sira p rn un hehehehehehe........... tnx
jopaw
Re: totally deadset
Post by DJFEL on Wed Nov 28, 2012 12:01 pm
ano model to...
Re: totally deadset
Post by jopaw on Wed Nov 28, 2012 2:50 pm
kc-21mk5
jopaw
Re: totally deadset
mern ka po b diagram ni2 wla po kc ko makuha
jopaw
Re: totally deadset
Post by triac on Wed Nov 28, 2012 3:06 pm
sis jopaw hindi madali masira yang transformer.Check nyo muna kung may B+ kayo,kung wala pakicheck yung HOT baka short..kung may B+ check nyo naman lahat ng secondary voltage..sana makatulong..sory wala po akong diagram,baka sa mga master natin meron..
Re: totally deadset
Post by jopaw on Wed Nov 28, 2012 3:27 pm
ok bro salamat, my b+ nmn sya, buo dn nmn ung regulator, pig tataka ko lng bat wla uotput voltage, samantalang my bigay nmn sa knya ung regulator na 300v wla lng ngang out put ung tansformer any idia pa po sa inyo tnx god blez
jopaw
Re: totally deadset
Post by triac on Wed Nov 28, 2012 3:33 pm
ilan ang nasukat mong B+?
Re: totally deadset
Post by triac on Wed Nov 28, 2012 3:35 pm
ang B+ sis yung voltage na nasusukat mo sa HOT collector pin.
Re: totally deadset
Post by jopaw on Wed Nov 28, 2012 3:38 pm
ung collector ng horizontal?
jopaw
Re: totally deadset
Post by triac on Wed Nov 28, 2012 5:24 pm
opo sis...
Re: totally deadset
Post by DJFEL on Thu Nov 29, 2012 4:40 pm
ano kaya apdit neto..chik mo f normal ba ba yong b+ neto..chik mo x-out neto baka sira.
Re: totally deadset
Post by DJFEL on Thu Nov 29, 2012 4:43 pm
chik lahat sa secondry supply f ok ba yong risistor naka connect sa B+...
Re: totally deadset
Post by baddypepito on Thu Nov 29, 2012 7:41 pm
huwag lang focus sa primary side ng transformer. dapat meron xang secondary voltages,, 125 at 12v
Re: totally deadset
Post by Electro on Fri Nov 30, 2012 1:16 pm
master hindi madaling masira ang mga chopper transformer. may tanong ako master nag iipon ba ng DC ang primary capacitor? pag ganyan ang status focus lang tayo master sa power supply
Re: totally deadset
Post by jopaw on Fri Nov 30, 2012 4:03 pm
bos djfel; wla po po ma read sa b+
bos triac; wla rn po ma raed sa collector ng horizontal
bos electro: nag iipon nmn po ng voltahe ung main cap.
tnx sa mga coments, xensya n sa abala hehehehe beginer lng po sa ma2lungan nyo po ako tnx ng marami...... Very Happy
jopaw
Re: totally deadset
Post by jopaw on Fri Nov 30, 2012 4:52 pm
mga master possible po kya n deffective po ung nabili ko n regulator ung drain pin nya 316v ung vcc pin 12v bukod po dun ung iba pang pins wla n po boltahe tnx
jopaw
Re: totally deadset
Post by jopaw on Fri Nov 30, 2012 4:55 pm
3s0680rf ito po pla ung regulator tnx ulit
jopaw
Re: totally deadset
Post by Hertz on Fri Nov 30, 2012 5:53 pm
jopaw wrote:kc-21mk5
PTUM01 chassis. hintay ka sa iba baka makompirma nila
jopaw wrote:bos djfel; wla po po ma read sa b+
palatandaan na hindi nga gumagana ang regulator.
jopaw wrote:mga master possible po kya n deffective po ung nabili ko n regulator ung drain pin nya 316v ung vcc pin 12v bukod po dun ung iba pang pins wla n po boltahe tnx
wag mo munang paghinalaan agad ang regulator mo. wala ka kasing primary B+ 310VDC sa pin1 (drain)
ito ang example ng ibang tv model na gumagamit ng 3s0680rf
basa ka na rin ng datasheet
http://www.alldatasheet.com/datasheet-pdf/pdf/53212/FAIRCHILD/KA3S0680RFB.html
Re: totally deadset
Post by jopaw on Fri Nov 30, 2012 9:19 pm
master marami salamat po malaki 2long na rin po ito para sa mga ref. ko... salamat nr po sa efort master
jopaw
Re: totally deadset
Post by DJFEL on Sat Dec 01, 2012 10:18 am
sub...focus ka mona sa primary my sira dyan...fusible resistor at saka chins value..
Re: totally deadset
Post by ultrasonicâ„¢ on Sat Dec 01, 2012 10:54 am
agreed Ptum01nga yata to..
@sis jopaw saan ka ng ga ground? sa - ba ng primary caps... ?
mababa yata ang pin3 (12v) mo.. try mu yang echeck. sundan mu si sis djfel.. resistor na change value hnapin.. sali mu na rin lhat ng peripherals parts sa pgchecheck bago hatulan ulit ang Reg...
@hertz anong wlang supply sa pin1 ? eh ang laki ng post niya
I
V
hahahaha nka Gante din (^_^
Re: totally deadset
Post by DJFEL on Sun Dec 02, 2012 10:08 am
sub...ano apdit neto..focus ka mona frimary...alarohen mo lahat dyan..
Re: totally deadset
Post by DJFEL on Sun Dec 02, 2012 10:16 am
ultrasonicâ„¢ wrote:agreed Ptum01nga yata to..
I
V
yong sinabe ni sis ultra..saan kaya naka ground to..
Re: totally deadset
Post by jopaw on Mon Dec 03, 2012 7:25 am
mga master sa negative ng main cap. po ako nag ground, d po b? pag hot po ang voltage checking kailangan sa negative po ng main cap...... tnx, master ultra meron po b kyo diagram nito? tnx..
jopaw
Re: totally deadset
Post by DJFEL on Mon Dec 03, 2012 9:36 am
jopaw wrote:mga master sa negative ng main cap. po ako nag ground, d po b? pag hot po ang voltage checking kailangan sa negative po ng main cap...... tnx, master ultra meron po b kyo diagram nito? tnx..
tama yan..so..na chik mo ba yong risistor or diode baka my sira sa primary..
Re: totally deadset
