NEED SERVICE MODE MENU FOR SHARP CINEMABORG 21V-J100M
AELEXIAN EMPIRE :: Analog and Mixed Signal Device Repair (Electronics Technician Board) :: (Electronics Technician Board) :: Television Repair
Page 1 of 1 • Share •
Mga master pahelp naman po kailangan ko lang malaman at panu pasukin ang service mode menu ng sharp cinemaborg 21V-J100M.Ala po kasi sound after ko magawa ang tv eto..pls.help..thanks..
jojogreg- AAA Battery
Re: NEED SERVICE MODE MENU FOR SHARP CINEMABORG 21V-J100M
nabigay na sa'yo ni baddy ang link
http://aelexian.4rumer.com/t127-sharp-cinemaborg
Hertz- Admin
salamat master Hertz..
mga master pahelp naman po uli problem ko sa gingawa ko na sharp 21V-100JM na tungkol po sa service menu na hanggang ngayon ay hindi ko parin maayos.kasi after ko po kasi nagawa ang unit e ala naman po kaya nga po nahingi ako ng tulong tungkol sa service menu ng ng tv na eto.Napansin ko kasi dun sa schematic diagram na ginamit ko sa repair ko sa unit sa unang first 5pages ay andun nakalagay on how to access service mode at adjustment at guide sa setting.Follow instruction lang din ang ginawa ko base dun sa data na nakalagay.eto yung mga nakalagay..
Service Number :Adjustment item: Data
: (init. value)(range)
s01 picture 55 00-7F
s02 Tint 46 00-7F
s03 color 32 00-7F
s04 brigthness 40 00-7F
s05 sharpness 28 00-3F
s06 vertical phase 00 00-07
s07 horiz.phase 12 00-1F
s08 rf-agc 2A 00-3F
s09 vertical amp 20 00-3F
s10 vco 2C 00-7F
s11 r cut-off 00 00-FF
s12 g cut-off 00 00-FF
s13 b cut-off 00 00-FF
s14 g gain 7F 00-FF
s15 b gain 7F 00-FF
s16 trap 3.58mhz 00 00 or
s17 balance 20 00-3Fset to 20
s18 c.c. position 18 00-7F
s19 y-mute 00 00- 00 normal
OP option(set to each model) 80 set to 08(20/21
M1 mts level 0A 00-0F
M02 stereo-vco 20 00-3F
M03 filter 1C 00-3F
M04 low separation 20 00-3F
M05 high separation 1B 00-3F
ginawa ko na po lahat ng setting na yan then holding down both the ch.up/down keys on the tv set at service mode for more than 2seconds will automatically write the above initial values into IC2101.which is the eeprom ic.After 2s shutdown ang tv then power on ko ulit using power button ganun parin ala parin sound pero normal ang picture sa lahat ng channel...anu po ba ang kulang na hindi ko pa nagawa mga master?iniisip ko kasi baka hindi sya parehas sa model sa 21v-100m?any advise mga master knukulit na ako ng mayari kasi ngtitiis nlang sila na alang sound..
s02 Tint 46 00-7F
s03 color 32 00-7F
s08 rf-agc 2A 00-3F
s10 vco 2C 00-7F
s14 g gain 7F 00-FF
s15 b gain 7F 00-FF
M03 filter 1C 00-3F
na try mu bang palitan ang data parameter na OP
gawin mong 10
sayang di ko dala ang notes ko.. di ko tuloy makonfirm kng ano ang j100
gawin mong 10
ultrasonic™- D Battery
uu nga pala sis.. na konfirm mu na ba na ok ang audio section nyu...? by hanging the iput pin ng sound ic kasali na nakadisable ang mute circuit.. nkapag insert na ng external audio source like radio fm/mp3 at tumunog... if done i can assure u na tama ang daang tinatahak natin
opo master kasi napansin ko pag ang OP setting ay nasa 08 nagnonormal po ang sound pagdating sa mga M tulad ng MO1,MO2 no sound sa MO3,MO4 at MO5 meron sound at naiilipat din sa ibang channel using remote control.pressing both chan.up/down to save the setting pero pagpower on using power button ala parin sound pero ang picture as is perfect picture.kahit ilipat sa ibang channel ganun parin.volume control display ok naman nagbabago pero no sound parin..
teka lng di ko masxadong masundan.. ang ibig mo bang sabihin na sa OP-08 ay ok ang sound pero pangit ang picture ?
MO1, MO2 = walang sound pero matino ang picture ?
MO3 - MO5 meron sound at may katinuan ang picture ?
tip ko lang paisa isa lang ang paadjust.. wag sabay sabay...
then check lagi na after na power off... na save ba ang new settings mo...
btw.. sampakan mo nlng kaya yan ng new eeprom na may laman na may tamang data "reprogram nlng"
yes master ultra,pag sa OP setting base sa service mode must be
OP-08 then paglipat sa
M01= nagkakaroon na ng sound with normal or good picture.
M02= no sound naman but good picture parin.
M03=with sound na naman at normal picture.
M04 = '' '' '' '' ''
M05 = " " " " "
then nasasave naman ang mga setting na yan pagbumalik ka uli sa service mode menu...sa normal operation powering up using power button display good picture naman pero ala parin sound..
master panu ba pagreprogram ng eeprom kng sakaling kailangan na palitan?...available ba yan sa electronics store na pagbibilhan?
M05 = " " " " "
may DIY projects dito sis... madali lang gawin.
baddypepito- C Battery
@master baddypepito,puede ko ba mahingi ang DIY projects na yan?need ko na po talga matapos etong hindi matapos tapos na problema ko sa service mode ng tv na eto..salamat po..
hanapin mo lang dito sa site sir jojogreg meron dito...
triac- D Battery
jojogreg wrote:yes master ultra,pag sa OP setting base sa service mode must be
M05 = " " " " "
master panu ba pagreprogram ng eeprom kng sakaling kailangan na palitan?...available ba yan sa electronics store na pagbibilhan?![]()
very strange.. parang di nagsesave ang data mo.. try mu nga sis ilista ung dati mong data at i compare mo sa bago mung data... para mas makita mo...
abwt sa Programmer eto pasok ka dito sis
http://aelexian.4rumer.com/t473-diy-eeprom-programmer-kit-serial-version-by-seph-pete-ng-elab
master ultrasonic kailangan pa ba ng software to be install para magamit ang eeprom programmer na yan?
uu sir.. needed mo ng software.. Ponyprog ang tawag... may guide tutorial akng gnawa sa 2nd page ng bingay kng link sa itaas.. review nyu lng maiigi... at eclick mu lng ang mga naka kulay na font naka embeded/nkahyperlink na yan
for the eeprom dump ng j100m...
eto dl mo... -> sharp 20V-J100M
courtesy of master kagz ng elab
pg na replace mu na yan... i mean na reprogram ang eeprom ic at same pa rin ang status... wlang improvement.. that's the time na simulan mu ng araruhin ang mga small ecaps sa paligid ng system con... bago palitan ng panibagong system con ic
lupit mo talaga master ultrasonic™. kaya hangang hanga ako sayo. idol talaga kita
Electro- D Battery
Page 1 of 1
