What tools or electronics equipment and components needed as technician or hobbyist?
Post by zhayzee on Fri Aug 31, 2012 5:55 pm
Mga sir pwedi po bang malaman based on your experiences kung anu-ano yung mga tools needed at least meron ang isang tech or hobbyist.
1. Soldering Tools
a. Soldering Iron ( best brand? how many watts?inch of the tip?)
b. Soldering Iron stand
c. Lead solder or rosin ( what is 60/40 or 63/37 means? what to buy?)
d. Solder wick or solder sucker/desolder pump (is it really needed?)
2. Hand Tools
a. Electric drill and drill bits (best brand/model? ranges of drill bits?)
b. Wire stripper/wire cutter (brand/model u use?)
c. Pliers (brand/model u use?)
d. Screwdriver (brand/model u use?)
e. Tweezers
f. Hammer (brand/model u use?)
4. Multimeter
a. Analog (best brand/quality?)
b. Digital (best brand?)
5. Solderless Prototyping Board a.k.a. “Breadboard”
- how big and what is the brand name of the breadboard u are using?
6. Wires and Clip leads
- stranded or solid wires? mostly used wire size?
7. AC/DC Adapter/ Linear Regulator/ SMPS
- what is the best to use? with what current rating?
8. Electronic components
- resistors, capacitors, IC's, relays, 555 timer, etc
Pakidagdag nalang din po sa mga nakalimutan ko.
Salamat po mga sir.
zhayzee
Re: What tools or electronics equipment and components needed as technician or hobbyist?
Post by 01110011 on Fri Aug 31, 2012 7:40 pm
yung sa akin
1.soldering eqpt.
broadway 40 watt iron at goot na 30 watts
soldering stand
60/40 lead yung available sa amin ( AFAIKmixture po yun ng lead at tin )
at desoldering pump
2.hand tools
bosch hand drill
china drill press
assorted bits
needle nose pliers
combination pliers
cutter pliers
rubber mallet
multimeter
sanwa analog meter
newstar digital
3.breadboard
cdrking breadboard
4.alligator clip wires
at least 10 pcs.
5.computer PS
as bench supply
6.components
stock up on:
resistors
mylars
electrolytics
diodes
resistors
knobs
switches
i suggest not to stock ICs because they might get damaged if unused for a long period of time
Post by ultrasonic™ on Sat Sep 01, 2012 1:11 pm
Soldering Tools
long life tip ang gamit ko @40W
optional sa akin to.. kuripot ako eh
mostly 60/40 ang lagi kng gamit..
uu nmn needed yan.. for me, sa desoldering pump dlawa ang gamit ko..
ganito
at ganito
2. Hand Tools
for hobbyist at small projz lng... pwde na ang mini drill
e. Tweezers
ok na sa akin khit wlang brand (^_^
4. Multimeter
a. Analog (best brand/quality?) Sanwa yx360trf Rolling Eyes
b. Digital (best brand?) Sanwa cd800a Rolling Eyes
di ko na mtandaan ang akin.. basta noong student pa ko ng T.. 1 whole size ang gamit ko. like this
defende sa application na pggagamitan
sa akin kng for solid = utp/telephone wire
for stranded = hook up wire ang gamit ko..
for me ok na sa akin ang adjustable ps using lm317/lm350
at syempre bench psu ng desktop computer...
mag stock ka lng ng common value
i agreed with 15W (^_^
lalot kng wlang aircon
btw grabe ka sis zhayzee.. dami mung tanong
Post by james on Sat Sep 01, 2012 10:34 pm
1. Soldering iron ko 30watts galing ng deeco a120 noon matibay naman. Pang solda ng mga pcb.
Soldering iron stand kailangan baka kasi maipatong sa ac cord hehehe.
Lead basta sa electronic store di pa naman ako nakakakuha ng pangit kapag tiangge at bangketa asahan mo karaniwan parang pangbubong.
Pero meron rin ako ng soldering at desoldering pump in one galing ng tiangge.
2. Electric drill ng deeco pang pcb
Sa wire stripper tama na ang pliers at blade cutters basta orig ang talim.
Pliers galing sa hardware, stanley or yung ibang taiwan made tapos lagay ng dagdag na insulator sa handle. Basta maganda ang ngipin.
Screwdrivers basta galing rin ng hardware ok naman. Yung ibang maliliit pwede na sa cdrking pero kung gusto mo ng matigas hanap ka sa ace or hardware din.
Tweezer yung mga pang cellphone or sa quiapo quality.
Hammer bili ka rin sa hardware wag sa tiangge for safety reason.
3. Multimeter kapag instrumentation fluke, sanwa. Pang harabas at sacrificial cdrking at tiangge brand.
4.Breadboard cdrking meron na rin, alexan, san pa ba.
5. Wires sa clip dapat stranded different size according to voltage at current.
6. Adapter with traffo will suffice most of the time with fix at regulated output. 1A most of the time.
7. Electronics components
Stock ka ng most of the value available gastos ka ng 1,000 @25 cents 20 pieces per value
ceramic 1000 @50cents
Post by zhayzee on Mon Sep 03, 2012 5:12 pm
heheh salamat po mga sirs ang babait nyo tlaga Very Happy
hindi po kasi ako mahilig sa repair, tska wala akong alam tlga sa mga magagandang brand.
Nka 3 na ata ako ng soldering iron, marami ding akong elex components, may breadboard din kaso hindi ko nagagamit..
nakikihiram lang ako ng power supply, electrical tape, hand tools at iba pa sa tatay ko Very Happy
zhayzee
Post by zhayzee on Mon Sep 03, 2012 5:16 pm
at tsaka minsan hindi ko na naisasauli hehehehe
kaya laging may award
zhayzee
Post by ultrasonic™ on Tue Sep 04, 2012 10:45 am
^ nyahahaha bad girl..
kng ano ang hnirap dpat angkinin.... lol!
btw tama.. mganda din ang fluke na tester...
wheeler din na brand...
Post by ultrasonic™ on Tue Sep 04, 2012 11:30 am
ay mali pala.. dapat pala sinasauli (^_^
Post by danny on Tue Sep 04, 2012 12:51 pm
salamat sa mga tips
Post by ultrasonic™ on Tue Sep 04, 2012 1:48 pm
saan tips sir danny... ung bang pgsasauli ng gamit ng iba lol!
peace
oie tama.. +1 pala kina 15w at sis james
Post by danny on Wed Sep 05, 2012 3:46 pm
hahahaha Very Happy
Post by ultrasonic™ on Wed Sep 05, 2012 4:41 pm
sir danny.. atin atin lng ito.. kilala mu ba yang si sis zhayzee?
duda kasi akng member din xa ng elab...
Post by james on Fri Sep 07, 2012 9:00 pm
zhayzee wrote:at tsaka minsan hindi ko na naisasauli hehehehe
Nasubukan mo na bang manghiram ng gamit ki sir admin?
Post by 01110011 on Sat Sep 08, 2012 5:12 pm
good news ate ultra, malayo na sa pinas si baklaray ;D balita ko kinain na ng australian creatures Very Happy Very Happy Very Happy
thanks po sa +
buti pa si zhayzee nanghihiram, while ako nagpapahiram Very Happy (di na sinasauli minsan)
Post by james on Sat Sep 08, 2012 10:59 pm
Pwede rin bang makahiram ng oscilloscope sa iyo sir fifteenwatts?
salamat pala sa point. meron na pala ako di ko alam kung sino nagbigay sakin ng una.
Post by ultrasonic™ on Mon Sep 10, 2012 10:30 am
nyahahaha puro DIY ang mga instrument at equipment ko (^_^
puro kalansay..kya mgdadalwang isip silang mnghihirap lol!
fifteenwatts wrote:good news ate ultra, malayo na sa pinas si baklaray ;D balita ko kinain na ng australian creatures Very Happy Very Happy Very Happy
thanks po sa +
uu nga eh.. nbasa ko din dun sa elab. pinapaingat ko pa nga xa sa mga kafederation nya. kasi iba na ang mga culture ng tao sa Australia (^_^
BTW OT na pla ako. di pala ito chitchat.. (^_^ hinayjack ko na ang thread ni zhayzee... sori sis... ang maidadagdag ko nlng..
sa mga ngsisimula pa lng sa electronics. pwde na khit papano ang mga wlang brand bastat mura. basic tools lng kailngan para mkapgsimula ng mg-xplore.. always know nlng kng papano ang proper pggamit ng tools para di tuluyang masira
Post by 01110011 on Mon Sep 10, 2012 7:53 pm
nung starting pa lang ako soldering iron turnilyo at gunting lang Banana dancing
Post by ultrasonic™ on Wed Sep 12, 2012 4:11 pm
sa cnabi mu sis.. naalala ko tuloy noong tym na ngsisimula din ako..
elemntary pa ko.. wla tlgang pera pangbili ng basic tools.. ung mga screw driver ko lalo na ang mga precision ay alambre/tie wire..
dini-form ko lng ang end side na maging flat gamit ang bato (stone) lol!
so far effectve nmn kasi nkakapag open ako ng mga pambatang electronc gadget lalo na ang break game console, game boy & etc.
hahaiz sarap alalahanin na sa bwat pglipas ng araw at panahon unti unti kang natototo
Post by james on Wed Sep 12, 2012 7:29 pm
Akala ko ako lang ang mahirap dito. Ganyan din dati gawa ko di pukpok na mga screw driver sa bato. :face:
Post by ultrasonic™ on Thu Sep 13, 2012 11:14 am
^ uu nga sis eh.. nasa ating na nga siguro ang courage na matoto..
eka nga nila passion (^_^
Post by zhayzee on Thu Sep 13, 2012 7:50 pm
passion fruit? heheh
Mga sir, thank you so much for patiently answering all my queries and I know it's a lot.
LongLive! cheers
zhayzee
Post by 01110011 on Thu Sep 13, 2012 9:56 pm
yung precission tool ko noong una is yung umbrella nail Very Happy at mga pako, first time kong magsolder gamit ko ay bakal na pinainit, usually kinukuha ko yung maliliit na motors sa mga laruan heheheheh
Post by ultrasonic™ on Sat Sep 15, 2012 7:48 pm
damo man diay ta nga same og experience (^_^
ako noon happy na mapailaw ang bulb ng flash light gamit ang size D or AA" battery.. series form or parallel... hahahahhaa
grabeh.. di ko pa alam kng paano magcharge ng batt nun.. hnggang sa dumating ang tym na binibilad ko nlng sa araw ang mga battery/cell... tapoz kabit ulit sa bulb.. ayon umilaw na naman ng malakas hahahahaha.. paano kaya yun.... (^_^
meron din isang way.. na dinidigdig/pinupokpok ko ang battery ng materyo o bato (stone) para macompress iyong carbonize sa loob... at ikakabit ko na nmn ulit sa bulb.. kaboom umilaw na naman hahahaha... ang liit tlga ng happinies ko nun (^_^
but im so happy for what i am now.. kasi patuloy pa rin natototo (^_^
sana nga lng di ako maimpluwensyahan ng mga bakla (^_^
Post by james on Tue Sep 18, 2012 9:25 pm
ano po kaya ang iba pang tools na maganda?
Post by Digitap on Wed Sep 19, 2012 7:54 pm
Oscilloscope, AF / RF Generator, signal injector, signal analyzer, solder pot, hot station Razz
