BOOSTER AMPLIFIER (MONO) using MJ2955
Page 5 of 12 Previous  1, 2, 3, 4, 5, 6 ... 10, 11, 12  Next
Re: BOOSTER AMPLIFIER (MONO) using MJ2955
Post by 01110011 on Fri Dec 09, 2011 7:21 pm
this is my booster amplifier
Post by arkin on Sat Dec 10, 2011 8:33 am
bakit mag auto switch off ang psu?
Post by mitch on Sat Dec 10, 2011 8:53 am
eh project din sa kaibigan ko b4 binigay lng sayang nmn kc may 3v - 12v selector..ano po pwd bibili nlng ako bago transformer at ako nlng assemble ng full wave.?ganda umaga pala sayo at sa lahat nka OL.
mitch
Post by arkin on Sun Dec 11, 2011 1:17 pm
bili kana lng,ok na 10 amp.sayang lng yon masyadong malaki,damihan mo lng diode,pra matibay supply mo.hwug rin masyado malaki voltage rating ng capacitor.ok na 25v.
Post by arkin on Sun Dec 11, 2011 1:26 pm
fiftenwats,dami yata ng input mo,pro kunti lng resistor mo.ano setup ng input mo,paralel lng in at out,tsaka bias?
Post by 01110011 on Mon Dec 12, 2011 8:18 pm
ano ba ibig sabihin mo diko ma gets
Post by mult on Mon Dec 12, 2011 11:24 pm
bumili kanang an 214 na ic amp yan yong gawin mong pre amp driver or gawa kanang 4558 jrc na pre amp para magawa mo ang 3way tone control
mult
Post by arkin on Tue Dec 13, 2011 8:37 am
bale yong setup ng input mo.dba 2 input gamit mo per chanel?nakaparalel lng ba lahat to?[sa mono side lng ha]mula sa input mo[galing sa amplifier]patungong transistor.ilang resistor ba gamit mo lahat2?[mas madali cguro pag ganito tanong ko] Very Happy
Post by 01110011 on Tue Dec 13, 2011 1:45 pm
dalawa lang po kagaya nung schematic the difference is yung input transformer eh naka series
Post by arkin on Tue Dec 13, 2011 5:40 pm
sa tingin ko mali yong gnawa mo?[series ba talaga o paralel?pkiguhit nlng cguro pra mkita ko mabuti Laughing sa tingin mo malakas ba sounds mo?san mo nkuha yang ganyang setup?pwede post mo rin ano gamit mo driver sa booster mo.nkagawa na rin ako ng ganyang setup,pro ibang-iba sa gawa mo.
tnx po..
Post by mitch on Wed Dec 14, 2011 9:16 am
arkin wrote:fiftenwats,dami yata ng input mo,pro kunti lng resistor mo.ano setup ng input mo,paralel lng in at out,tsaka bias?
salamat po..gumagama po yong booster ko pro di nagtagal kc parang scratchy..mainit po yong isa kong power transistor ano po yon?siba ba??
mitch
Post by arkin on Wed Dec 14, 2011 9:30 am
ilang transistor gamit mo per chanel,kong 2 lng per chanel talaga magbabaga sa init nyan.kilangan dagdagan mo pa ng transstor pra d masyadong mainit.o d kya,plitan mo resstor mo sa ground,taas mo ng kunti.kong sinunod mo yong nasa furom nato,dapat plitan mo 500 ohms.
Post by popcorn on Wed Dec 14, 2011 2:55 pm
paano ba pag distorted ang sound ng booster pag hinaan ko ang volume? anong parts ang papalitan ko o change value nga ba ng resistors?
popcorn
Post by arkin on Wed Dec 14, 2011 3:36 pm
plitan mo ng mas maliit na value yong resistor sa ground.dka marunong ng V.D.F.?mas ok if marunong ko non,kc mdali lng maresolve yong ganyang problema.ano value ng resistor mo sa ground?clue:if 500ohms rsstor mo sa grnd,baba mo kunti,cguro mga 470.depende rin kc yan sa dami ng transstor mo.
Post by 01110011 on Wed Dec 14, 2011 5:24 pm
arkin wrote:sa tingin ko mali yong gnawa mo?[series ba talaga o paralel?pkiguhit nlng cguro pra mkita ko mabuti Laughing sa tingin mo malakas ba sounds mo?san mo nkuha yang ganyang setup?pwede post mo rin ano gamit mo driver sa booster mo.nkagawa na rin ako ng ganyang setup,pro ibang-iba sa gawa mo.
ito po yung kadalasang setup dito sa amin dual input transformer.
yung pinagdrive ko po is yung pioneer KP500 na head unit,
hindi ko po ginagamit tong booster ko, wala naman akong sasakyan eh Very Happy
ginagamit ko sa bahay ay power amp :albino:
Post by arkin on Thu Dec 15, 2011 2:15 pm
taga cebu din ako tol.nkagawa na rin ako ng dual input.nsubakan ko na ring i-series,akala ko rin npa2lakas sounds sa gnitong setup,mali pla.lalo lng humihina sounds ko Very Happy .bakit?kc,nahahati lng yong input.gaya sa speaker,pagnkaseries humihina,pag nkapralel lumalakas.sa setup na to klangan mataas bias[maliit value sa ground resistor]kc distorted sounds sa low level volume.
Post by 01110011 on Thu Dec 15, 2011 2:32 pm
oo cge na parallel pala yung input Very Happy Very Happy
Post by dizon on Fri Dec 16, 2011 11:15 am
mga master ano po iyong v.d.f ?
dizon
Post by arkin on Sat Dec 24, 2011 4:25 pm
voltage divider formula yan..
Post by dizon on Mon Dec 26, 2011 4:27 pm
salamat po master. point sa inyo
dizon
Post by Electro on Mon Dec 26, 2011 6:17 pm
arkin wrote:pwede,basta d baba sa 10 amp ang current.mas maganda pa yan sa trans4mer.ingat lng sa chasis,dilikado kc ang ground nyan.
salamat po master. +1 sayo subukan ko na lang
fifteenwatts wrote:mag auto switch off ang PSU nyan
bakit mag ooff master fif ?
Post by jan™ on Tue Dec 27, 2011 11:11 pm
mga master, unsay nakalahi sa Zero Distortion ug Interceptor diri sa Cebu?
jan™
Post by arkin on Wed Dec 28, 2011 3:15 pm
spelling! Very Happy
Post by arkin on Thu Dec 29, 2011 8:54 pm
unsa pasabot nmo nakalahi sa ZD og Inter..?
Post by jan™ on Mon Jan 02, 2012 7:59 pm
ang timpla master gud,, =)) ma intriga man gud ko, puro baya sila gagamit ug booster, pero unsay nakalahi nila?
jan™
