SONY TV problem
SONY TV problem
Post by fire on Tue Jan 31, 2012 10:52 am
mga master pa help nmn.no power and no light indicator.i check primary reading is 310v.secondary is 115v.tpos meron ako naririnig na huming sounds.d ko malaman kung ecap b sya pero malapit sa primary ung tunog.tinangal ko na ung fbt pero may huming sounds pa rin.help TY Lovingly yours helen.
fire
Re: SONY TV problem
Post by zandertech on Mon Feb 06, 2012 12:24 am
sir baka po e.cap yan sa sec0ndary circuit,..ung 160v110uf,.or higher uf,.....or baka po walang supply sa driver mu kaya ganun,....check mu nlng ulet sir,..
Re: SONY TV problem
Post by ultrasonic™ on Mon Feb 06, 2012 7:09 pm
mlamang my heavy load sa mga LV supply ng SMPT(hula mode) (^_^
basic check nlng muna.. lhat ng out sa PSU... bka my shorted na zener diode or leak parts
Re: SONY TV problem
Post by ultrasonic™ on Mon Feb 06, 2012 7:11 pm
pwde din sa sound amp. hula rin (^_^
Re: SONY TV problem
Post by samiel on Mon Feb 06, 2012 7:25 pm
ano model number ng unit
samiel
Re: SONY TV problem
Post by Electro on Wed Feb 22, 2012 4:28 pm
oo nga master fire. ano model number ng tv?
Re: SONY TV problem
Post by zandertech on Fri Mar 02, 2012 8:45 pm
Ou nga kadalasan may shortage or leakage sa secondary circiut,,check mu po sir mga regulator kung mer0n man,.
Re: SONY TV problem
Post by batmantech on Mon Mar 19, 2012 9:54 pm
waiting
Re: SONY TV problem
Post by arkin on Tue Mar 20, 2012 7:16 am
my b+ ba sa fbt?my mga sony kc na my ic protector.kadalasan dyan nagkamali ibang technician.pki chek lng yong power led,f magblink ba kong e power up ang main switch.
Re: SONY TV problem
Post by bjohn798 on Tue Mar 20, 2012 5:30 pm
master arkin saan po ba nakalagay ang ic protector? nasa between ba to ng primary at secondary power supply?
bjohn798
Re: SONY TV problem
Post by arkin on Wed Mar 21, 2012 12:27 pm
nasa b+ yan,115volts ptungng flyback.prang cyang 2 pin transistor..
Re: SONY TV problem
Post by Electro on Wed Mar 21, 2012 6:19 pm
parang nakita ko na iyan master sa mga sony. transistor ang mukha pero dalawa lang ang paa. para siyang fuse na nag oopen lage
Re: SONY TV problem
Post by samiel on Wed Mar 21, 2012 9:22 pm
ic link ata tawag nyan sa sony...pero ang function nya fuse lang talaga.
samiel
Re: SONY TV problem
