otl booster (output transformerless)
Post by longthrow on Fri Jan 20, 2012 9:58 am
otl w/ trimmer:
otl w/ servo:
split psu:
notes:
using dmm, adjust trimmer to set output closest to 0Vdc & should not be more than +/-50mV
its better to use A1943 & C5200 than MJ2955 & 2N3055 if you want to crank more power
also after upgrading, you can run it further to +/-40v supply (30v-0-30v ac)
longthrow
Re: otl booster (output transformerless)
Post by 01110011 on Sat Jan 21, 2012 12:16 pm
wow galing! new version ng classic booster amp
Post by arkin on Sun Jan 22, 2012 10:05 am
sa ako to sir design longthrow.2 iya version:1.similar lng sa basic boster,using cutomized input[preha sa vt22]w/ separate bias resistor.emiter stabilizer sa output.split 12v power suply.ang 2nd,bsin similar sa imo design.sorry,im not sure!sealed man gud,naa something epoxy nga gibulit sa PCB..
Post by longthrow on Tue Jan 24, 2012 8:18 am
same diay sa akoa proj pag 2nd yr. college, niadtong 1998, pero +/- 18v ang supply. noted ang sec polarity else mag cancel ang output:
ang prob gud sa common emitter is stability, but it still works.
your almost there on the devt cheers
longthrow
Post by 01110011 on Wed Jan 25, 2012 7:24 pm
sir kung itaud ni sya sa sakyanan tagsa ug battery kada rail? o naa sya smps?
Post by longthrow on Wed Jan 25, 2012 8:59 pm
smps is the best psu para ani, either using tl494 or sg3525 & ferrite transformers.
pero naa pud simple alternative like this: (using laminated iron core)
pwede pud butangan og pulse driver @ 50% duty cycle & f=50-60Hz ang 3055 for added stability.
longthrow
Post by arkin on Fri Jan 27, 2012 4:25 pm
pwede ka gmit batery,pro doble.example:12v,2 ka batery imo gmiton since split suply mna..how?series nmo ang 2 batery[morag gi 24 bah]tap nmo ang b+ sa + terminal sa 1st bat.tap nmo b- sa - terminal sa 2nd bat.ang ground tap nmo sa + og - nga naglink sa duha ka batery.problem:on higher supy daghan batery imo knahanglan.
Post by 01110011 on Mon Jan 30, 2012 8:00 pm
ah cge salamat sirs Smile
mahala raba sa battery oi apologies
Post by arkin on Fri Feb 03, 2012 12:29 pm
longthrow,ask lng:connected na ang resistor sa output?[knang doul sa input]dba dapat ground na i-connect?
Post by longthrow on Wed Feb 08, 2012 11:10 am
connected sa output.
longthrow
Post by Deep Bass on Fri Jan 11, 2013 2:13 pm
mga sir magandang araw,pasensiya medyo mahina ako sa electronic,magtatanong lang sana,ano ang gamit sa trimmer dito?ano ang servo?at dmm?wait ko sa rply thanks GOD BLESS
Deep Bass
Post by longthrow on Fri Jan 11, 2013 7:33 pm
trimmer- manual zero offset voltage adjustment
servo- 741 ckt for automatic zero offset voltage adjustment
longthrow
Post by Deep Bass on Fri Jan 11, 2013 8:15 pm
sir longthrow thanks sa rply pwede visaya?hehe joke if ever mag assemble ko ani asa man ani ako sundun w/trimmer w/servo?if ever lang,thanks
Deep Bass
Post by longthrow on Sat Jan 12, 2013 12:58 am
ang naay servo para walay hasol sa trimmer og mas accurate gyud nga ang output dc offset is @ minimum regardless on the supply fluctuation.
longthrow
Post by Deep Bass on Sat Jan 12, 2013 1:27 pm
thank you so much master,more power sau,thank you so much gyud sa pag share sa imo knowledge,pasensiyae na me mga newbie
Deep Bass
Post by pyroelectro on Sat Jan 26, 2013 12:28 pm
+1 sayo sir longthrow. Ganda ng Design
Post by michael nierva on Mon May 06, 2013 3:34 pm
mga master pwede nyo po ba akong matulongan about booster amp. using mj2955, kung panu mag rewind ng audio output transformer 500 watts mono o any reference kung paanu ako makakapaggawa tnks
michael nierva
Post by brylle45 on Mon Jun 03, 2013 7:49 pm
ilan po ang wattage nito po sir?
brylle45
Post by longthrow on Mon Jun 03, 2013 8:03 pm
approx 100w into 8ohms using 30-0-30 transformer
longthrow
