sony 14" vertical problem
Post by zandertech on Tue Jan 17, 2012 9:18 pm
sir ask lng po ako bout sony na 14" vertical nya eh may white line pero isang line lng sa taas ,. all caps are checked and changed in vertical section pero ganun pa rin even the vertical ic was replaced wala pa rin luck .,sony na surplus po ito ung may 110v transformer,. i forgot the model ,. wat po kaya possible problem? doubt thanks mga boss
Re: sony 14" vertical problem
Post by ultrasonic™ on Wed Jan 18, 2012 1:40 pm
pwde change value resist at leak small ecap sa vert. yan....
pwde din kapos sa supply..
Post by willyboy on Thu Jan 19, 2012 12:08 pm
sir..tama si bossing..na experience ko yan nung nag trouble ako sa TCL problem..
una problem..horizontal line lang sa center.. double Line ngalang..
nung nagpalit ako ng resistor at capacitor IC ng VERTICAl IC301
R306A na47kat ecapsC305 na2.2/50V ayun naOK..
pero may thin Line naman sa taas( like your problem)..nagpalit lang akoEcaps saVCCng Vertical IC (c308 with valueof 100UF/35V) ayun ok na..
as of Now..Buhayparin TCL ko.. lol!
willyboy
Post by zandertech on Thu Jan 19, 2012 3:34 pm
Ah,.cge ho try ko ulet double check mga boss,..pero parang napalitan ko nrin ata ung caps sa VCC line ng vertical..,dalawang 35v100uf nga ata un,..posible po kyang may trouble sa jungle ito?,sa vertical out ng jungle?
Post by ultrasonic™ on Thu Jan 19, 2012 4:34 pm
yapz possible din. pero kunti lng ang chances
rate ko siguro only 5% (^_^ hula mode
jejejeje patient ang kailangan mu jan
check mu lng maigi ang mga peripheral parts ng Vert. zander
resist, caps at diode
Post by ultrasonic™ on Thu Jan 19, 2012 4:36 pm
pero kng color rgb linings yan tumuon sa 9V supply lalot SONY iyan
Post by zandertech on Thu Jan 19, 2012 4:38 pm
Ah cge boss,...hirap talaga kausap ng sony tv's haha,.
Post by ultrasonic™ on Fri Jan 20, 2012 11:07 am
nyahahha butit. knakausap ka nya...
kya mu yan ;D
tiyaga lng (^_^
Post by zandertech on Fri Jan 20, 2012 12:06 pm
Weakness ku talaga yang sony minsan, unlike any other televis0n,.haha,.
Post by ultrasonic™ on Fri Jan 20, 2012 6:37 pm
sa mga protection circuit ka lng siguro nalilito (^_^
Post by jojogreg on Thu Oct 18, 2012 12:24 pm
ako rin nagugulohan at nahirapan dyn kay sony..panu ba kaibiganin etong si sony para maging maamo sya pagmay problema mga master?
jojogreg
Post by triac on Sat Oct 20, 2012 10:02 am
pati ako nahihirapan..sir ultra paano ba malalaman ang protection circuit?
Post by arkin on Mon Oct 22, 2012 5:57 pm
agree..kng my color yong line mlamang nsa rgb problem n2.chek lng maigi ang color ng picture tube,f my isang color na lamang sa iba,my troble na tube mo..
Post by arkin on Mon Oct 22, 2012 5:58 pm
ot:dba mtalagal lumabas picture n2?
Post by ultrasonic™ on Tue Oct 23, 2012 6:10 pm
^ uu nga sis arkin.. kya nga pinapa aware ko na normal sa Sony ang ganyan (^_^
triac wrote:pati ako nahihirapan..sir ultra paano ba malalaman ang protection circuit?
hhmmmpppff bwat model at chassis my knya kanyang Prot.... at tawag din.. sa sobrang dami ng TV models bka di natin ma tackle...
kya focus nlng muna tau sa Sony lalot sony itong tnutrouble ni TS... (^_^
mostly sa mga Sony lalot mga GMR series ba yun, di ko na malaala.. my mga resistor na 1/8W na nkaseries sa secondary B+ line.. kng susundan mu yun ay dadalhin ka nyan sa iba ibang Protection circuit.. try to float or condemn them. pg gumana. expect na nandoon sa section na un ang my problema. expect din na pwde my umusok o pumutok. pwde nyu din gamitin ang SONY BLINKING CODE as a guidelines sa troubleshooting nyu.. but dont expect too much.. kasi pg my problema ang system con/cpu/mcu.. di na yan susunod sa Code...
sa Xray Protection nmn.. its a form of HV mylar caps na nka connect sa B+ hnggang Collector pin ng HOT...
for Video muting, mostly sa mga lumang modelo ng Sony my IK return sa C board hanggang Jungle/Chrome.. try to condemn them by cutting & put signal diode back to Chroma. parang ganito...
read more
sa ibang modelo wlang silang IK circuit.. iba ang protection nila... white balance scanner tawag ng iba... ah basta madamo pa jud...
sa audio nmn.. for the sound muting.. alam nyu na yata ito... look for the datasheets nlng at alamin ang mute pin ng sound ic.. mostly transistorize ang switching nito...
for the tuner.. look scl & sda at supply ng 33v
for ABL sundan lng ang FBT pin... its a form of resistor & zeners
yan nlng muna
sana mkatulong (^_^
btw i forgot to tell na ang protection circuit ay hindi para lituhin ang technician, ito ay protection ng Manufacturer to avoid more worse/damage sa Unit nila...
Post by triac on Sat Oct 27, 2012 10:01 am
salamat po sir ultra malaking tulong na po ito,salamat po at mataas po pasensya nyo to explain..godbless po... Very Happy
Post by Hertz on Sat Oct 27, 2012 1:39 pm
pwede hanap ng datasheet ng system at jungle at tignan kong may Protection pin
Post by ultrasonic™ on Sat Oct 27, 2012 5:09 pm
^ super agreed.. pg nhanap na ang pin lhat ng dadaanan nya ay lhat suspect for protecting the tv units...
triac wrote:salamat po sir ultra malaking tulong na po ito,salamat po at mataas po pasensya nyo to explain..godbless po... Very Happy
ur welcome sis... share share lng po tau for the benefits of the new generation (^_^
btw for some other model... kng IK protection at white balance Prot ang tawag sa knila.. Discharge Protection Ckt at Spot killer circuit naman ang tawag namin sa LG
Post by DJFEL on Sat Nov 24, 2012 2:00 pm
hinde ba ma taas yong g2 neto...alarohen mo lahat vertical section...mylar cap..chik mo rin...
Post by triac on Tue Nov 27, 2012 9:59 am
@sir hertz salamat po sa idea mo..
@sir ultra salamat po sa explanation nyo..
Post by DJFEL on Wed Nov 28, 2012 12:04 pm
ano apdit neto..
Post by Electro on Fri Nov 30, 2012 1:20 pm
may natutunan na naman ako. +1 sa mga master
Post by DJFEL on Mon Dec 03, 2012 9:38 am
sub....
Post by zandertech on Sun Jan 06, 2013 11:56 am
sir ok na to nakuha ko sa factory setting inudjust ung vertical salamat mga bossing Smile ,.nga po pla speaking of protection circuit na try ko na mag bypass pero malabo ung pic Smile
Post by DJFEL on Sun Jan 06, 2013 5:12 pm
bang...ok na pala...congrats...
