BOOSTER AMPLIFIER (STEREO) using MJ2955 5 2 4
Page 2 of 10 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Re: BOOSTER AMPLIFIER (STEREO) using MJ2955
Post by 01110011 on Wed Jan 18, 2012 8:32 pm
arkin wrote:wla nmang dapat i-eliminate dyan.lines crossing without a dot is not connected.mas maganda kong mas mataas ng driver amp.pwede an7161 or tda2005,khit yong mga car stereo na 35w.mas maganda ang bass kapag malkas ang drive,wag lng masyadong mataas.nasubokan kna sakura[nkalimotan ko yng model#,yong TIP lng ang output trans]ang ganda ng bass.lakihan lng ang input trans4mr.
what i meant to say is baka maguluhan sila, kasi marami yung 12v at GND Very Happy Very Happy Very Happy
01110011
Post by ytsertoto on Thu Jan 19, 2012 9:00 am
tnx mga tropa.....
ytsertoto
Post by arkin on Thu Jan 19, 2012 9:24 am
ah!ok..
Post by ytsertoto on Fri Jan 20, 2012 12:46 am
mga tropa pano gagawin pag distorted yung output/sound ng booster amplifier.tnx
ytsertoto
Post by arkin on Fri Jan 27, 2012 3:06 pm
ibaba ng kunti yong ground resistor.example:470ohms,gawin mong 400ohms.kung masyadong mainit yong pwer trans,itaas mo yong value.
Post by 01110011 on Mon Jan 30, 2012 7:03 pm
korek ;D
may naka-encounter na sa inyu nga ang bass & treble niinit kaayu ?
unsa kahay daut ani sir?
naa gihapon sya music kusog man sad pero init kaayo ang pre-amp ??
01110011
Post by arkin on Fri Feb 03, 2012 11:13 am
unsa type sa pre-amp?d jud cya common since pre-amp rman cya.
Post by 01110011 on Sun Feb 05, 2012 7:35 pm
kanang bass treble gani sir init gyud mga 5 seconds ra mahikap bisan lmedium ra ang iyang volume
01110011
Post by arkin on Tue Feb 07, 2012 6:58 pm
unsa nga psa ang init|?
Post by Mylene on Mon Feb 13, 2012 11:40 am
baka ang potentio ang umiinit Razz
Mylene
Post by renelachica88 on Thu Feb 16, 2012 3:52 pm
Yung TR1 ay RDL-I at yung TR2 ay RDL-O. 33 ohms at 270 ohms na resistor @ 1 watt . Sa Raon pa kami bumibili noon. Sorry medyo matagal na kasing project namin yan sa high school at di ako sigurado kung may gumagawa pa ng ganung transformer. Actually yung ginamit naming transistor noon ay Genuine na 2SB449 o 2SB337. Resistors are 4.7 and 470 ohms. That was year 1979 pa.
renelachica88
quadro booster
Post by bhongskieboie on Mon Mar 19, 2012 12:28 am
sir gae kog diagram sa kwadro nga booster b galibog mn gud ko kay duha duha mn iyang input ..nangaputol nmn gud tawn ang wiring ani akong booster kay dugay nmn ni wala magamit , as in nanga puka ang mga sinuldahan...... hope inyo ko ma tebangan ... salamat
bhongskieboie
Post by arkin on Tue Mar 20, 2012 6:02 am
same rna s mono nga booster.gi times four lng na.meaning,ang set up sa mono,ghimo lng upat pra ma kwadro.kopyaha lng na ang ubang chanel nga ok pa..
Post by bhongskieboie on Wed Mar 21, 2012 2:48 pm
so bale ang duha ka input parihas ra xa ug wiring diay.... nya ang resistor niya boss pila nman ibutang ani? ug usa ang sakto pag butang? salamat daan... bag o paman ko ani boss
bhongskieboie
Post by arkin on Sat Apr 14, 2012 7:23 pm
copy lng sa gipost..
