BOOSTER AMPLIFIER (STEREO) using MJ2955
Page 1 of 9 1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Post by mitch on Mon Jan 02, 2012 9:29 am
mga sir..belated hapi new year..thanks sa tanan advice..pwd ask ko about sa stereo using MJ2955 at yung schem diag at pati wiring diagran..thanks agin more power.. ☀
mitch
Re: BOOSTER AMPLIFIER (STEREO) using MJ2955
Post by Digitap on Mon Jan 02, 2012 8:46 pm
gawa po kayo ng dalawang ganito.
from book of pagirigan
Note:
The value of R1 and R2 470Ω vary from one input transformer to another. Common value of R1 is from 4.7Ω, 10Ω, 12Ω up to 15Ω. In case of distortion, try substituting the value of R1. In case of excessive heating of output transistor, try to substituting R2 470Ω with a lower value say 330Ω or 390Ω.
nandito po ang ibang information
Post by arkin on Mon Jan 02, 2012 8:58 pm
baliktad yata mayalin?dlang sa trans4mer klangan i-vary ang value ng resistor,sa dami rin ng transistor na gamitin.
Post by mitch on Wed Jan 04, 2012 7:57 pm
di po ba kagaya yan ng mono na booster parang mgakatulad lng..saan may indicator po left at right nyan?
mitch
Post by arkin on Thu Jan 05, 2012 8:57 am
preho lng talaga,gawa ka ng dalawa nyan.depende lng yan source mo kong san sya nkakabit,wla problema khit saan mo ikabit,sa left or right.d magmumulto yan pag baligtad. aware
pwd na ba ito??
Post by mitch on Fri Jan 06, 2012 1:01 am
sorry po di ako marunong magpost ng image baka pwd paki view nlng ng link o pa click sa image..
mitch
Post by arkin on Sat Jan 07, 2012 6:00 pm
ganyan nga..khit saang chanel ikabit mo,pwede.
Post by 01110011 on Sun Jan 08, 2012 10:02 am
i eliminate nyo po yung VCC at GND na malapit sa speaker
Post by AC-DC Electronics (TJ) on Mon Jan 09, 2012 6:03 pm
good..
Post by AC-DC Electronics (TJ) on Mon Jan 09, 2012 6:05 pm
10 watts pababa ang magandang aligay na amp sa input ni2ng booster na iyan with tone control.... Very Happy
Post by 01110011 on Mon Jan 09, 2012 10:26 pm
^yep pwede an7169,uPC1230 o kung meron an214 marami pa Smile
paki lagay ng marker
Post by mitch on Tue Jan 10, 2012 8:35 am
paki lagay po ng marker kong asan ang vcc at gnd na eliminate.,.salamat po..
mitch
Post by arkin on Tue Jan 10, 2012 10:18 am
wla nmang dapat i-eliminate dyan.lines crossing without a dot is not connected.mas maganda kong mas mataas ng driver amp.pwede an7161 or tda2005,khit yong mga car stereo na 35w.mas maganda ang bass kapag malkas ang drive,wag lng masyadong mataas.nasubokan kna sakura[nkalimotan ko yng model#,yong TIP lng ang output trans]ang ganda ng bass.lakihan lng ang input trans4mr.
Post by ytsertoto on Tue Jan 17, 2012 4:27 am
mga tropa bka pwede mkahingi schematic diagram ng booster amplifier..bago lang ako dito sa forum na to tnx..
ytsertoto
Post by arkin on Wed Jan 18, 2012 7:10 pm
yong nsa taas,yan ang booster amp..stereo pa nga yan.
Post by 01110011 on Wed Jan 18, 2012 9:32 pm
arkin wrote:wla nmang dapat i-eliminate dyan.lines crossing without a dot is not connected.mas maganda kong mas mataas ng driver amp.pwede an7161 or tda2005,khit yong mga car stereo na 35w.mas maganda ang bass kapag malkas ang drive,wag lng masyadong mataas.nasubokan kna sakura[nkalimotan ko yng model#,yong TIP lng ang output trans]ang ganda ng bass.lakihan lng ang input trans4mr.
what i meant to say is baka maguluhan sila, kasi marami yung 12v at GND Very Happy Very Happy Very Happy
Post by ytsertoto on Thu Jan 19, 2012 10:00 am
tnx mga tropa.....
ytsertoto
Post by arkin on Thu Jan 19, 2012 10:24 am
ah!ok..
Post by ytsertoto on Fri Jan 20, 2012 1:46 am
mga tropa pano gagawin pag distorted yung output/sound ng booster amplifier.tnx
ytsertoto
Post by arkin on Fri Jan 27, 2012 4:06 pm
ibaba ng kunti yong ground resistor.example:470ohms,gawin mong 400ohms.kung masyadong mainit yong pwer trans,itaas mo yong value.
Post by 01110011 on Mon Jan 30, 2012 8:03 pm
korek ;D
may naka-encounter na sa inyu nga ang bass & treble niinit kaayu ?
unsa kahay daut ani sir?
naa gihapon sya music kusog man sad pero init kaayo ang pre-amp ??
Post by arkin on Fri Feb 03, 2012 12:13 pm
unsa type sa pre-amp?d jud cya common since pre-amp rman cya.
Post by 01110011 on Sun Feb 05, 2012 8:35 pm
kanang bass treble gani sir init gyud mga 5 seconds ra mahikap bisan lmedium ra ang iyang volume
Post by arkin on Tue Feb 07, 2012 7:58 pm
unsa nga psa ang init|?
Post by Digitap on Mon Feb 13, 2012 12:40 pm
baka ang potentio ang umiinit Razz
