120W Power inverter
120W Power inverter
Post by ultrasonic™ on Thu Aug 19, 2010 11:18 pm
This Circuit Design is one of the most cheapest inverter i ever had. its containing a square wave design using a 555 as a timer, and a 7404 to provide alternating pulses for the transformer windings. The 2SD880s and 2N3055s work as a Darlington pair to amplify the signals coming from the logic chip, and the 2N3055 do the hard work of switching the current. They are rated at 15A max, 10A is a safe operating value, that gives around 120W of power at 12V. They should be mounted on proper heatsinks with proper electrical isolation (the collector is the transistor's body).
Take Note:
naay kulang sa diagram nga two protection diodes. kng wla na xang duha ka diode it can cause na madaot ang emng power transistor after a few seconds of operation. kanang two diodes kay itaod ninyo between sa ground ug sa collector terminal sa 2N3055's both side, in reverse, so they normally won't conduct.
PARTLIST:
Transformer 12V center Tap (approx. 12Amps)
2pcs. 2N3055 NPN Power Transistor
2pcs. 2SD880 NPN Transistor
2pcs. AN4662/1N4007 Rectifier Diode
1pc. LM555 timer IC
1pc. 7404 inverter ic (Logic)
1pc. KA7805 regulator (5V)
1pc. 1000uf/25V or 470uf/16V e. caps
1pc. 10uf/16V or 100uf/16V e.caps
1pc. 150kilo ohm resistor 1/4w
1pc. 1kilo ohm resistor 1/4w
2pcs 100ohm or 400 ohms 1/4W
Construction:
testing for the 7404's output using two pairing of LED
testing the power transistor using two automotive 12V 20W bago itaod ang Transformer
Final Testing Before Finishing (^_^)
Final Output:
kayo na bahala sa Box Enclosure
Re: 120W Power inverter
Post by zandertech on Tue Nov 15, 2011 1:54 am
nice to ah ,..thanks sa sharing boss ,. kaso dili ko gyud maintindihan ung bisayan word na iba hehehe,..pano po pla ung koneksyon ng ic 7407?
Post by Digitap on Wed Nov 16, 2011 6:51 pm
ganito po yata waiting
Post by zandertech on Wed Nov 16, 2011 8:36 pm
ai ganun pla ,...thanks miss ganda Very Happy
Post by mars_828 on Thu Aug 09, 2012 12:58 pm
pano po pla ung koneksyon ng ic 7404 ung pin assignment?. at anong value ng resistor na nakakabit sa 555 timer?
mars_828
http://gonzales.mmars@yahoo.com
Post by mars_828 on Thu Aug 09, 2012 7:56 pm
mars_828 wrote:pano po pla ung koneksyon ng ic 555 ung pin assignment?. at anong value ng resistor na nakakabit sa 555 timer?
mars_828
Post by ultrasonic™ on Thu Aug 16, 2012 10:50 am
sori ngyon ko lng ito napansin... my kulang sa diagram at my mali rin.. redit ko muna
Post by danny on Thu Aug 16, 2012 4:26 pm
meron kang modified sine wave?
Post by Digitap on Sat Aug 18, 2012 2:15 pm
sir ito ang kulang diba?
connect pin6 and pin2
connect pin8 and pin4
resistor 150k on pin8 and pin7
resistor 1K on pin7 and pin6
Razz
Post by ultrasonic™ on Sat Aug 25, 2012 3:09 pm
sapol mu princess (^_^
nku wla akng modified ~ wave sir
Post by DJFEL on Tue Jul 30, 2013 7:48 pm
eto yong 120 watts inverter ko...2nd yr collage pa to..binohay ko ngayon..
