GROUNDED NOKIA PHONE
Post by kim yu on Sun Dec 18, 2011 7:40 pm
mga master patulong nman kong panu ayusin ang phone kpag grounded, nokia 1110 e2 po ang model 1110..
more power and god bless us all... peace
kim yu
Re: GROUNDED NOKIA PHONE
Post by Digitap on Mon Dec 19, 2011 5:45 pm
nabasa ba iyan ng tubig ?
Post by kim yu on Thu Dec 22, 2011 9:51 pm
0o nbasa poh..
kim yu
Post by ultrasonicâ„¢ on Fri Dec 23, 2011 12:57 pm
princess nahulog siguro sa dagat o Canal Razz
jokz lng TS
@kim nabuksan mu na ba? bka basa pa ang kaloob-looban nyan..
gamit ka ng torx T6. pangbukas nyan
Post by kim yu on Mon Dec 26, 2011 4:07 pm
bnuksan ko na poh master tsaka hnugasan ko na din po ng lacquer thinner tsaka bnilad ko sa araw..d pa rin mwala ang ground master.. Question
kim yu
Post by Electro on Mon Dec 26, 2011 6:11 pm
pa abang
Post by Digitap on Sat Dec 31, 2011 7:59 pm
kim yu. bakit mo nasasabing grounded pa rin ?
Post by kim yu on Mon Jan 09, 2012 11:20 pm
ahm,tenesteran ko ung terminal ng batt,short na short kaya ko nsabi may ground,kasi kpag wlang ground may reading cya kpag tenesteran mo.. Very Happy
kim yu
Post by Electro on Tue Jan 10, 2012 11:55 am
baka may shorted na parts sa line ng b+. master mahirap yata mag ayos ng cp pag walang soldering blower ba tawag dun scratch
Post by konektado on Wed Jan 11, 2012 12:18 am
master kim yu,,gamitan mo ng hot air..kasi kahit bnilad mo n xa d p din sapat un kc bka npasok nya ung mg ic jn..so mg soshort p dn tlga un,,if gagamtan mo xa nun,,dpat ung tamang settings lng kc,,bka mgctalsikan ung mga,resistor nya,,gudlak master,,,
konektado
Post by zandertech on Wed Jan 11, 2012 10:33 am
boss check mo ung rectangular caps nya na pinakamalaki ,... or minsan namn sa PA na sya, need mo hotair boss
Post by goukie on Fri Feb 17, 2012 9:18 am
TIPS ON HOW TO HANDLE GROUNDED OR SHORTED PHONE
FIRST PANU MALAMAN IF SHORTED O GROUNDED.
USED MULTI TESTER LAGAY MO SA X1,PUT THE TEST POD ON + AND - TERMINAL OF THE PHONE.
IF PUMALO NG BALIKTARAN,MAGKAPAREHO ANG READING,IT MEANS SHORTED ANG PHONE,IF PUMALO NG BALIKTARAN NOT IN THE SAME READING,IT MEANS GROUNDED LANG.
* ACTION : BABAD NYO MUNA SA LOQUER THINER FOR A FEW MINS,APPLY BRUSH PARA MATANGGAL ANG KALAWANG O DUMI,APPLY HOT AIR OR BLOWER PARA MATUYO.
NOTE:WAG IBILAD SA ARAW MASISIRA ANG BOARD O PYESA,AND OTHER COMPONENTS,LIKE LCD.
*IF THE GROUND OR THE UNIT STILL SHORTED,CHEK NYO LANG PO UNG MGA PARTS NA MAY KALAWANG,MOSTLY MGA CAPACITOR.OR BATT, TERMINAL OR PYESA SA ILALIM,
*TANGGAL AND CHECK COMPONENTS IF NO LUCK,IBANG PARTS ULIT.TYAGA LANG TILL MATANGGAL.
MAHIRAP PO TALAGA AUSIN ANG MGA GANYANG PROBLEM NG UNIT.
GOOD LUCK.
goukie
Post by Jmark217 on Mon May 21, 2012 9:16 am
Boss kadalasan yung dalawang malaki na capacitor sa ibaba ng UEMK power ic ang shorted diyan,subukan mong tanggalin.
Jmark217
Post by Electro on Sat May 26, 2012 12:25 pm
master Jmark217 ano iyong UEMK power ic ?
Post by Blaze25 on Mon Jun 18, 2012 11:47 am
Babad mo sa thiner for 30minutes at tingnan mo din kung corroded na ang malalaking capacitor sa tabi ng sim interface at tingnan din PA niyan.
Last edited by Blaze25 on Mon Jun 18, 2012 11:47 am; edited 1 time in total (Reason for editing : edit)
Blaze25
Post by ton_allen on Sun Aug 26, 2012 9:40 pm
hi po sa lahat.. bago lang po ako dito:)... sir babad mo po muna sa thiner.... mga 1hr... kapag grounded parin try mo isa isahing angat ung mga capacitor..... angat mo sa bord tapus tester mo.. wag mo muna galawin ung mga ic... sir gamit ka po ng hot air...
ton_allen
