LG SERVICE MODE
LG SERVICE MODE
Post by ultrasonic™ on Fri Nov 18, 2011 9:09 am
Service Mode for LG TV series
1.for old model series
press 7392 of REMOCON (TV should be in ON mode)
2.for new model series (except sa pinaka-latest model ngayon hah)
press menu of REMOCON & press menu in TV set
Re: LG SERVICE MODE
Post by mrjames123 on Mon Jul 09, 2012 4:37 pm
galing mo bay.
mrjames123
Re: LG SERVICE MODE
Post by james on Fri Sep 07, 2012 9:24 pm
Para san po ba ang service mode? noob po pasensya na.
Re: LG SERVICE MODE
Post by ultrasonic™ on Mon Sep 10, 2012 12:36 pm
mgagamit mo yan kng meron kang gustong i adjust sa default settings nya like vertical size, vert. hold, horizontal size, sound volume, agc, RGB, pincusion size & etc... sa mga lumang modelo na wla pang S.mode.. they are using preset service sw. (trimmer adj.)
Note:
SERVICE MODE WARNING:
Without proper documentation and training, you can probably do quite a good job of messing up your television set, perhaps even damaging it.
Don't mess around with the service mode adjustments unless you know what you're doing and have the service manual to guide you.
Once you enter service mode the first thing you should do is record all the original values BEFORE you change anything! - This is the only way to restore the television to its original (factory default) state should it become necessary to do so.
Your results with these procedures may vary and can NOT be guaranteed to work on your particular television set USE THEM AT YOU OWN RISK.
kya mas refer ko na kng meron mn kayong babaguhin sa mga data parameter at di nyu masxadong gamay ang model unit
mas mainam ilista muna sa malinis na papel ang orig data. para kng sakali mn mgkamali o gustong ibalik sa dati ay maibabalik tlga (^_^
Re: LG SERVICE MODE
Post by DJFEL on Fri Jan 25, 2013 1:26 pm
solat mona...baka ma sira yong computer ko pg dating nang panahon..
Re: LG SERVICE MODE
