Cellular Phone calling Detector
Post by Hertz on Thu Aug 19, 2010 9:31 pm
* Flashes a LED when detecting an incoming call
* Powered by one 1.5V cell
Circuit diagram:
Parts:
R1 = 100K 1/4W Resistor
R2 = 3K9 1/4W Resistor
R3 = 1M 1/4W Resistor
C1, C2 = 100nF 63V Polyester Capacitors
C3 = 220µF 25V Electrolytic Capacitor
D1 = LED Red 10mm. Ultra-bright (see Notes)
D2 = 1N5819 40V 1A Schottky-barrier Diode (see Notes)
Q1 = BC547 45V 100mA NPN Transistor
IC1 = 7555 or TS555CN CMOS Timer IC
L1 = Sensor coil (see Notes)
B1 = 1.5V Battery (AA or AAA cell etc.)
Device purpose:
This circuit was designed to detect when a call is incoming in a cellular phone (even when the calling tone of the device is switched-off) by means of a flashing LED.
The device must be placed a few centimeters from the cellular phone, so
its sensor coil L1 can detect the field emitted by the phone receiver
during an incoming call.
Circuit operation:
The signal detected by the sensor coil is amplified by transistor Q1 and drives the monostable input pin of IC1. The IC's output voltage is doubled by C2 & D2 in order to drive the high-efficiency
ultra-bright LED at a suitable peak-voltage.
Notes:
* Stand-by current drawing is less than 200µA, therefore a power on/off switch is unnecessary.
* Sensitivity of this circuit depends on the sensor coil type.
* L1 can be made by winding 130 to 150 turns of 0.2 mm. enameled wire on a 5 cm. diameter former (e.g. a can). Remove the coil from the former and
wind it with insulating tape, thus obtaining a stand-alone coil.
* A commercial 10mH miniature inductor, usually sold in the form of a tiny rectangular plastic box, can be used satisfactorily but with lower
sensitivity.
* IC1 must be a CMOS type: only these devices can safely operate at 1.5V supply or less.
* Any Schottky-barrier type diode can be used in place of the 1N5819: the BAT46 type is a very good choice.
