sony tvpicture problem patulong sir
Post by zandertech on Sat Oct 08, 2011 9:58 pm
may sony tv po ako walang picture pero may sound i'd try to adjust the screen wla parin nagkaroon lng ng white lines i've boost the heater ganun parin,.nagawa ko na rin i-by pass ung "ik" circuit wala pa rin ..................san kaya to mga boss may idea po ba kayo? salamat ,.... doubt
Re: sony tvpicture problem patulong sir
Post by peter on Sun Oct 09, 2011 4:55 pm
check voltage on G2 malamang dyan lang ang trouble
peter
Post by zandertech on Sun Oct 09, 2011 9:22 pm
meron din po boss,.ung unang sira na nakita ko is walang suply ung 1000v nia after checking i've found na open na ung resistor na nagsusuply dito then i changed it tapos un na lumabas blank screen lng sya,.pag i adjust ung screen white lines only ,.. doubt
Post by peter on Sun Oct 09, 2011 10:56 pm
ask lang po ilang ang exact reading ng G2 sa tube po.
peter
Post by ultrasonic™ on Mon Oct 10, 2011 2:59 pm
pwedng mahina na ang tube... needed ng mag rejuvinate
@TS post mu nga ang nasusukat mung screen voltage/G2 ?
para atleast makompirma natin
Post by samiel on Mon Oct 10, 2011 9:29 pm
zandertech...ano exact model ng sony tv mo? baka may mabigay tau exact details...chech u muna abl resistor mo malapit sa flyback
samiel
Post by peter on Tue Oct 11, 2011 8:09 am
kong abl dapat may osd sya weak tube siguro
peter
Post by samiel on Tue Oct 11, 2011 9:23 pm
kung tube cra nyan...pagtinaasan mo ng g2 or screen voltage hindi yan mag retrace line....depende sa model ng sony...pag gdr,gmr,str series cya , minsan pag abl ang problem no picture with sound...blanking cya pro blink ng blink lang ang ilaw sa harap...to confirm kung tube talaga....hang mo yung RGB sa tube mo at sukatan mo votahe nila,dapat halos parehas lang cla,or dapat nakahang yung tatlong RGB mismo sa tube,then idikit mo saglit to ground isaisa,dapat sobrang maliwanag bawat isa yan sa tuwing kinakabit mo sa ground...saltik lang...screen voltage dapat 500-600v pag malakas pa tube mo....malalaman u naman yan pagmalakas pa tube mo pagtinaasan mo ng g2 or creen voltage mag white lines yan....maganda kung bigay mo rin yung exact model ng sony tv mo....
samiel
Post by samiel on Tue Oct 11, 2011 9:28 pm
check mo rin rgb input sa C board,dapat magkaparehas voltage nila...if parehas ,nasa C board problem mo,check mo RGB output voltage nila dapat halos magkapareha lang...pero dapat nakahang RGB mo sa tube
samiel
Post by nelok28 on Sat Oct 15, 2011 5:27 pm
[quote="zandertech"]may sony tv po ako walang picture pero may sound i'd try to adjust the screen wla parin nagkaroon lng ng white lines i've boost the heater ganun parin,.nagawa ko na rin i-by pass ung "ik" circuit wala pa rin ..................san kaya to mga boss may idea po ba kayo? salamat ,.... doubt [/quote
palitan mo capacito mo 250 volts 330 uf then check mo tube mo kung maliwanag pa check 1000 v 200v ok
nelok28
Post by Electro on Sat Oct 15, 2011 6:37 pm
unsa ni nga model ? basig naa ni siyay IK. pupalong baya na ug video
Post by zandertech on Sat Oct 22, 2011 4:49 pm
sir ok na po ung tv napagtyagaan i trouble shoot,.sorry tagal di nakapagonline may sira po plang 1/4 watt resistor sa high voltage circuit papauntang jungle ic ayun ok na po salamat sa mga reply mga bossing
Post by zandertech on Sat Oct 22, 2011 4:51 pm
salamat mga sir ,...
Post by Electro on Sat Oct 22, 2011 5:54 pm
congrats zandertech. nasundan mo ba saang pin ng jungle siya papunta ?
Post by zandertech on Sat Oct 22, 2011 10:48 pm
naku di ko na po natandaan pero may board ako dito na kamukha nun check ko n lng boss tapos i post ko dito,..
Post by ultrasonic™ on Mon Oct 24, 2011 6:23 pm
baka abl resistor o di kaya video black path iyan...
@electro avoid magbisaya lol!
salamat
Post by Electro on Sat Oct 29, 2011 1:01 pm
sorry master ultrasonic™. nadala lang po
Post by totoy on Wed Nov 02, 2011 11:07 am
congrats pre...
totoy
Post by Hertz on Thu Nov 03, 2011 5:11 pm
congrats. dami na palang member dito lol!
Post by zandertech on Thu Nov 03, 2011 11:16 pm
thanks mga bossing nakakatuwa nga at meron tayong site na ganito na pwedeng makapagshare ng ating problem at issues tungkol sa servicing and repairing sets,...thnks sa bumuo nitong site at sa lahat ng admins angry
Post by nelok28 on Wed Dec 07, 2011 11:02 am
GOOd t.y sa info mo tol Magagaling tlga kayo..
nelok28
Post by nelok28 on Wed Dec 07, 2011 11:05 am
tama si master ultra yung Abl na resistor yun sinasabi mo papuntang h.v yunmaliit lang yun mga 100 k ata
nelok28
Post by zandertech on Thu Dec 08, 2011 7:25 pm
tama sir abl resitor nga yata un Very Happy
Post by samiel on Thu Dec 08, 2011 7:52 pm
malamang r857 and r816 location..abl nya
samiel
Post by batmantech on Wed Dec 21, 2011 10:21 pm
pag bleu yung screen san ung sira
