MoTank / Plagiarism tank
Post by pyroelectro on Thu Jul 14, 2011 8:19 pm
create your own mobot tanks
prepare all the material needed.
create tread contact surface by cutting aluminum sheet and bore a two hole to allow chain interface
This will be the drive train with the primary sprocket and chain
This is the Bosch wiper motor
Wheels what i will be using to drive the treads. Trolley or ladder wheels
sheetmetal 1.2mm electroplated frame
Left view
Top view
Isometric
From the isometric render you can see the 2x 7Ah batteries (1 battery for testing stage). Arduino Uno in the middle. 2 Wiper motors. Some dodgy brackets and shafts that still need some refinement. And obviously, those aggressive looking treads.
for operation system you can used H bridge
for controlling system you can used
RC , Infra , Bluetooth , Sensors and so on Wink
Source: PyroElectro.com
