TCL-21106 no power
TCL-21106 no power
Post by arcenio on Wed May 18, 2011 9:36 pm
hi...meron po ba kayong schematic diagram ng tcl tv model no..TCL-21106...thanks..pinalitan ko na po ka sya ng power regulator pumumutok parin ang fuse..
arcenio
Re: TCL-21106 no power
Post by pyroelectro on Wed May 18, 2011 10:31 pm
baka may problema kayo sa mga diodes
check mo dito ang diagram baka may nakapagpost na.
http://aelexian.4rumer.com/f14-television-schematic-diagram
Post by Oscar on Fri May 20, 2011 5:37 pm
baka may iba pang parts na short. diode, zener at switching ic
Post by arcenio on Sat May 21, 2011 5:50 pm
hello po,wala pa po nag post ng ganitong model..
arcenio
Post by ultrasonic™ on Sat May 21, 2011 6:43 pm
arcenio wrote:hello po,wala pa po nag post ng ganitong model..
post mu yung mga major parts as a bases natin.
jungle ?
system ?
limot ko na kng same lng ba ang tcl21106 sa tcl2106
bka same chassis cla.. check mu dito
tcl-2106 --> http://aelexian.4rumer.com/t226-tcl-tv-chassis-m23
Post by arcenio on Sat May 21, 2011 6:46 pm
sir ano bang password mo..nagdownload na kasi ako kaso encrypted pala ito files kailangan ko ng password..salamat
arcenio
Post by ultrasonic™ on Sat May 21, 2011 6:52 pm
passcode: sttm
check mu ng maigi ang viper ic mu bka short/leak na..
lhat ng peripherals ng reg ay suyurin ng maigi..
gamit ka ng incandescent bulb method to isolate the problem
Post by ultrasonic™ on Sat May 21, 2011 6:53 pm
pa OT:
lipat ko ang thread mu sa television repair thread
Post by arcenio on Sat May 21, 2011 6:57 pm
ok po...salamat
arcenio
Post by arcenio on Sat May 21, 2011 7:04 pm
sir yong ic nito na nakakabit sa supply ay 44608P40 tapos K2996 ang transistor
arcenio
Post by ultrasonic™ on Sat May 21, 2011 7:09 pm
mukhang ibang chassis nga yan...
kng 44608 ang viper nyan at mosfet k2996 ang power reg.
pwede mung bases ang tcl 2027u jan..
ito DL mu -> tcl2027u baka makatulong
for the passcode PM ko sayo.. check ur inbox
Post by ultrasonic™ on Sat May 21, 2011 9:27 pm
hahaizzz sa wakaz nakalkal ko din sa baul
check mu e2 arcenio
http://aelexian.4rumer.com/t311-tcl-tv-tcl-21106
yan ang mga major parts nya... compare mu nlng tapoz update mu ko
Powe Reg.: K3298 or K2996
Viper: MC44608
EEPROM : 24C08
UOC: TMPA8803CSN
Vertical : TDA8172
Sound : TDA7057AQ
AV sw. : TC4066BP
HOT: D2499
FBT : BSC25-0231
sanay tugma na yan
gudlak
Post by arcenio on Sun May 22, 2011 2:51 pm
update na lang ako sayo sir kung ok na ang tv
arcenio
Post by pyroelectro on Mon May 23, 2011 10:03 pm
nandito na pala si sir. @arcenio check mo lang nang maigi ang mga discrete parts sa power supply.
Post by Oscar on Tue May 24, 2011 8:07 pm
iba talaga itong si master ang daming diagram na nakatago.
Post by ultrasonic™ on Wed May 25, 2011 2:37 am
di nmn na tymingan lng jud na naa ta (^_^
@TS gudlak
Post by Hertz on Sat May 28, 2011 2:57 am
makiabang nga nito
Post by Electro on Wed Jun 01, 2011 8:12 pm
sinabi mo pa car. napaka resourceful talaga Very Happy
Post by arcenio on Thu Aug 04, 2011 6:19 pm
mga sir ito po ang parts sa tcl-21106
viper-44608P40
power reg.-K2996
horizontal-D1555
vertical-TDA8172
Jungle-TCL A15V02-T0
sound ic-TDA7057AQ
pinalitan ko na po sir ang viper at saka power regulator ganon parin pumutok parin na check ko narin ang mga diodes ok naman...
arcenio
Post by ultrasonic™ on Mon Aug 08, 2011 9:18 pm
naisolate nyu ba ang Horizontal section sa PSU ?
nang mas madaling mlamng kng saan ang dhilan kng bakit kau laging napuputukan ng fuse ?
hndi nmn cguro under rating ang fuse na nilagay nyu ? 3.15A
Post by arcenio on Fri Aug 12, 2011 5:39 pm
hi sir, hindi ko pa inasolate ang horizontal sir pero tinanggal ko sya para ma tester kong sira ok naman ang horizontal transistor..ang hindi ko maintindihan sir kong bakit palaging nasisira ang power reg. na K2966...
jumper lang kasi sir ang nilagay ko na fuse pansamantala sir...
arcenio
Post by arcenio on Fri Aug 12, 2011 5:42 pm
i print ko nalang siguro sir yong binigay mo sa akin na diagram para malaman ko kong saan pupunta ang mga supply nito..
arcenio
Post by ultrasonic™ on Fri Aug 12, 2011 6:22 pm
condemn mu muna ang horizontal section. by hanging one pin collector ng HOT o di kaya B+ pin ng FBT. para mlaman mu agad kng saan ang may problema. pag pumutok nasa psu nga ang problema at kng di nmn pumutok nasa horizontal ang probz Razz
gamit ka ng incandescent bulb method. parallel mu sa dlawang socket ng fuse holder. pg masxadong mliwanag ay may short ka pa o heavy load ka pa sa PSU... sa ganyang paraan ay di ka mauubusan ng glass fuse (^_^)
Post by arcenio on Fri Aug 12, 2011 7:45 pm
ok sir salamat po balitaan nalang kita kong ok na itong tv
arcenio
Post by nelok28 on Sat Oct 15, 2011 5:20 pm
arcenio wrote:hi...meron po ba kayong schematic diagram ng tcl tv model no..TCL-21106...thanks..pinalitan ko na po ka sya ng power regulator pumumutok parin ang fuse..
check mo capacitor mo tol baka shorted!!o kaya palitan mo yung controller mo na 66408 wag kang magkakamaling magkabaliktad then check mo yung fet regulator mo baka shorted na rin yun lang
nelok28
