Grounded Booster Amp
Post by glezore on Wed Feb 23, 2011 11:34 am
bakit grounded ang aking booster amp. w/mj2955.? ano po kaya ang problema nun?
glezore
Re: Grounded Booster Amp
Post by Oscar on Wed Feb 23, 2011 2:55 pm
bakt niyo nasabi na grounded ang booster amp niyo ? pumuputok ba lagi ang fuse
Post by glezore on Mon May 16, 2011 11:59 pm
Oscar, ok na rin... naayos ko na!
glezore
Post by volter on Tue May 17, 2011 8:20 pm
congratulations glezore.
anong naging problema ? share mo naman dito
4th member of STTM
former 5th member
volter
Post by glezore on Sat May 21, 2011 4:16 pm
nakadikit lng pala ung trible, volume at bass sa chassis... pero bkt mahina lng ang lumalabas na sounds?
glezore
Post by ultrasonic™ on Sat May 21, 2011 5:44 pm
oie body grounded pala. congratz
normal lng na muhina yan dahil di gumagana ng maigi ang tone control at preamp
Post by glezore on Tue May 24, 2011 5:45 pm
anung dapat kung gawin? papalitan ko ba? pasinsya na kyo sa kakulitan ha..
glezore
Post by Oscar on Tue May 24, 2011 8:24 pm
paghiwalayin na lang siguro ang dalawa
Post by ultrasonic™ on Wed May 25, 2011 2:20 am
tama si oscar.. separate the two circuits gamit kau ng insulated materials. plastics, mica, fish paper, fiber glass, porcelain, etc...
ng masisiguro mu lng na di na dumikit ung copper foil sa metal/aluminum casing
pwo kng ganito ang booster
pwede kang maglagay ng plastic spacer sa metal screws para mapa float mu ung pcb sa casing kita mu ung marking na pula sa ibabaw. jan mu ilalagay ang spacer.
image view ng spacer
Post by Oscar on Wed May 25, 2011 6:24 pm
dami mo talagang teknik master
Post by ultrasonic™ on Thu May 26, 2011 8:00 pm
di nmn yan technique. instinct lng kailangan.
Post by Elx2007 on Thu Oct 17, 2013 3:08 pm
ultrasonic ask q lng dba 5amps ung fuse ilang volts un ska anung value ng pilot light.? tnx..
Elx2007
Post by Mcdo Scout on Thu Nov 07, 2013 10:26 pm
saan nakakabili ng plastic spacer meron ba sa mga e.shop yan?
Mcdo Scout
Post by DJFEL on Tue Nov 12, 2013 8:49 am
kahit anong plastic spacer yong ginamet ko noon bolpin lang...
Post by DJFEL on Tue Nov 12, 2013 8:51 am
Elx2007 wrote:ultrasonic ask q lng dba 5amps ung fuse ilang volts un ska anung value ng pilot light.? tnx..
5 amp 220v ang fuse at saka 240v pilot light...ok na yan..
