Sharp TV ( Chassis MSA ) Primo E.board DUNTKA541WE
Post by ultrasonic™ on Fri Feb 18, 2011 6:52 pm
Sharp TV
Model Series:
20v-L70m
20v-L80m
21v-L70m
21v-L80m
20LK32
20LK62
E.board DUNTKA541WE
Chassis MSA
To enter the service mode and exit service mode.
Make a short circuit JA137 & JA138 for 1 second and release to switch to the service mode position, and the microprocessor is in input mode.(Adjustment through the I2C bus control.)
To exit the service mode, turn the television off by pressing the power button.
Major Parts:
Power Reg.: STRG5653
EEPROM: BR24C02F
UOC: IX3564CEN4, TDA9387PS/N2?311154
Vertical : TDA9302H / AN5522 / TDA9309
Sound : AN7523
HOT: 2SD2586
FBT : F0229PE, F0231PE
Tuner : ENV56D82-1
?AE5qSdNDHRk8>8?6)e(ED[54;:C<;ESj\%KrA?/S5J6>&L&H6,D-97F6^a;dplf:¶
]poTCd5E2D
key: simatar
Sharp Chassis MSA
Always on stndby after 5mins.
Post by Almer Presco on Fri Aug 05, 2011 11:41 am
My sharp 20V-L70M always switch to stndby mode after 5mins. of operation. I check voltage found normal. Pls. help tnks.
Almer Presco
Re: Sharp TV ( Chassis MSA ) Primo E.board DUNTKA541WE
Post by ultrasonic™ on Mon Aug 08, 2011 9:15 pm
Almer Presco wrote: My sharp 20V-L70M always switch to stndby mode after 5mins. of operation. I check voltage found normal. Pls. help tnks.
@almer try to create new thread for that on our television repair thread..
if i have tym i will guide u for ur troubleshooting
Post by batmantech on Thu Dec 22, 2011 11:19 am
pa help boss ung tv ko na ganyan pag nila2gyan ng back cover nama2tay pa help po
Post by ultrasonic™ on Fri Dec 23, 2011 12:49 pm
bka my loose con pa kau.. or pwdeng crack board like hair lines..
para mapadali gamit ka muna ng magnifying glass
Post by JEROME BARROCA on Mon Jan 30, 2012 3:04 pm
power reg number sharp tv model 21v-l70m
JEROME BARROCA
Post by JEROME BARROCA on Mon Jan 30, 2012 3:05 pm
di ko kasi makita ang number nya
kasi na bura
JEROME BARROCA
anu po yung number ng power regulator sharp tv model 21v-l70m
Post by JEROME BARROCA on Mon Jan 30, 2012 3:08 pm
JEROME BARROCA
Post by ultrasonic™ on Mon Jan 30, 2012 4:45 pm
JEROME BARROCA wrote:anu po yung number ng power regulator sharp tv model 21v-l70m
@jerome nailagay ko na sa ibabaw ang numero ng Power Regulator
STR-G5653
Post by mrtahimik on Sun Jul 29, 2012 4:56 pm
boss wala na po pabenta dito na power reg nyan..... pwede po ba transplant? boss pahingi naman data ng power supply nito or service diagram po...... maraming salamt boss
mrtahimik
Post by ultrasonic™ on Mon Jul 30, 2012 7:10 pm
^ try mung mg order through online kahit newport
Post by kaholito on Wed Aug 01, 2012 3:09 pm
saan po ba naka kuha ng diagram ng tv sa net ng libre.
Post by micosa16 on Sun Oct 14, 2012 1:07 am
ANO PO BA UNG VALUE NG R703 KC PO NAWALA DKO PO MAKITA MODEL 21V-L70M
micosa16
Post by Oscar on Sun Oct 14, 2012 7:56 pm
micosa16 47k 5w ang nakalagay sa diagram
Post by kaholito on Thu Oct 18, 2012 10:43 pm
un po bang str g6653 pwedeng palitan ng str g 5653?bkit 245 v ang lumabas sa secondary?wla naman akong makitang shorted na pyesa?
Post by ultrasonic™ on Tue Oct 23, 2012 4:47 pm
^ parang pwde yata yan sis... di lng ako xure, di ko lng marecall msxado sa utak ko kasi di ko mhanap ang notes ko... ung F6654 pwce din ung. reposition lng ng pins at medjo mlaki ang package size (^_^
Post by kaholito on Thu Oct 25, 2012 7:43 pm
nag try po ako replace ung str g6653 ng g5653.kaya lng po bakit prang nalampas ung boltahe ng primary cap sa secondary?280v sa sec b+ nainit ang sec cap.
Post by DJFEL on Sun Feb 10, 2013 2:24 pm
tnks neto sis ultra...mang ka pareha pala to sa 21v-lz30s
Post by kaholito on Mon Oct 07, 2013 3:28 pm
SHARP-14V-W70M(Primo) pareho lng po ba Ito ng diagram?primary section po kasi ang trouble.
Post by raven90110 on Mon Jan 30, 2017 9:29 am
sis meron ako dito sharp21v-l70m no power ayaw mag on standby mode lang!
raven90110
