sony component DXA-WZ88D/HCD-WZ88D
Post by triac on Sat Jan 06, 2018 10:55 am
Good Day mga Sis,
Ang problema ko dito evreytime i push the sound field botton i hear a(tok)sound and also when i turn the volume down when it reach to zero i hear a (tok)sound again.Mag ka Sis suspect ko ang supply niya ang may problema.Please help me any idea?Thank you.
Re: sony component DXA-WZ88D/HCD-WZ88D
Post by danny on Thu Jan 11, 2018 3:57 pm
another possible issue is the muting circuit
aside from power supply
i've seen these kind of problems sa ibang mga brand
Post by triac on Thu Jan 11, 2018 5:42 pm
Sir Danny salamat sa idea.Repair is on going.This coming saturday ko pa ito maasikaso..salamat sir.. Very Happy
Post by triac on Tue Jan 16, 2018 10:31 am
update ko lang ito mga sis...kinuha ng may ari hindi ko na solve yung tok na sound pero okay lang daw kasi first problem nito no power.Sir danny +1 pa rin sayo at least may idea na ako sa susunod.. Very Happy Very Happy Very Happy
Post by ultrasonic™ on Fri Jan 19, 2018 11:35 am
sayang nahuli ako...
kung dumaan iyan sa ibang tech sis triac.. pwede jinumper ng dating tech ang contact point ng Relay.. kaya ganyan ang effect..
or kung hindi naman human made iyan..
tiyak naka actuate/naka on mode lagi ang Relay Mo..
ang purpose kasi ng relay ckt na iyan ay para sa power delay.. pampa delay ng connection sa seaker line out... isa pa sa purpose niya ay para DC out detection... para autromatic mag protect ang unit kung may DC binabato ang amp sect para protectionan ang speaker na wag masunog..
nakalimutan ko anong tamang technical term dyan sa tok sound na yan...
si Sis danica alam iyan ^_^
Post by triac on Mon Jan 22, 2018 10:53 am
@sir ultra...okay lang po sir ultra alam ko na busy po kayo..for discussion lang po sir..ako po ang first na naka repair nito sir ultra.saang banda e check ito sir?sa relay section?
Post by ultrasonic™ on Thu Jan 25, 2018 10:47 pm
sa may Spkr out malapit iyan.. may relay dyan na magka cut sa line path nila.. check mo baka naka actuate/naka on lagi ang relay..
Double check mga ecap malapit sa relay yan kasi ang isa sa pampadelay ng actuation niya
Post by triac on Fri Jan 26, 2018 11:16 am
thank for the info sir ultra...+1 points pa rin sayo..salamat sa idea baka sa susunod madali ko na... cheers
