Tcl ultra slim. No power.
Post by geof79 on Sat Nov 18, 2017 3:30 pm
Pa help nman d2. Sbi nun my ari ng tv nliit ang screen taz pg pnupukpok nbalik sa katinuan. Hngang mwlan na ng power. Pg check ko putok ang fuse taz cra regulator JCS7N60F. My iba ba pwede pmalit d2. Wla pa kc ako mbili pareho number. Taz my mga lobo na ecaps. D ko na nkuha m0del. Dnala ko lng board nito. Ang parts power ic NCP1337P vertical LA78141
hot D5024
Sna my mgreply. Tnx
geof79
Re: Tcl ultra slim. No power.
Post by geof79 on Sun Nov 19, 2017 10:53 pm
Swak kya d2 ang K2645 o K2996? Sna my mgreply para mkausad ako. Tnx advance.
geof79
Post by timroa on Mon Nov 20, 2017 5:58 pm
swak yan sis nakapagtry nako nyan.
timroa
Post by geof79 on Mon Nov 20, 2017 6:44 pm
Tnx sis. Hawig kc board na i2 dun sa tcl 21M63US na gumagamit ng k2996. Kya naicp ko bka pwd kht un k2645.
geof79
Post by geof79 on Tue Nov 21, 2017 12:08 pm
My ibng cra pa cguro i2. Pag power ko parang my sumisipol sa primary. Nabagsak ntaas ang b+.
geof79
Post by geof79 on Tue Nov 21, 2017 12:31 pm
Ska my stock na kuryente sa 2 at 6 ng vertical. D kya 2luyan nrin i2 bumigay?.
geof79
Post by triac on Wed Nov 22, 2017 11:33 am
basa lang po para matutu.
Post by Hertz on Wed Nov 22, 2017 9:38 pm
float mo ang vertical ic. baka shorted o baka yoke iyan
Post by geof79 on Wed Nov 22, 2017 11:50 pm
Ok sir hertz. Tnx sa reply.
geof79
Post by geof79 on Thu Nov 23, 2017 12:01 am
Pwd rin kya d2 ang la78040 or 45?
geof79
Post by geof79 on Thu Nov 23, 2017 12:15 pm
Ask ko nrin pla un transistor C144 kung anu functi0n kc un isang paa d pumapalo sa tester kht pagpalit palitin. Dlawang paa lng un my function. Di ko pa kc kbisado i2. Kung cra man i2 anu pang replacement sa ganito? Tnx
geof79
Post by Hertz on Fri Nov 24, 2017 11:20 pm
geof79 wrote:Pwd rin kya d2 ang la78040 or 45?
Mas mataas ang 45 sa Power kaysa sa 40 pero pareho lang ang pin. Ginagawa iyang substitution ng mga kapwa mong technician.
geof79 wrote:Ask ko nrin pla un transistor C144 kung anu functi0n kc un isang paa d pumapalo sa tester kht pagpalit palitin. Dlawang paa lng un my function. Di ko pa kc kbisado i2. Kung cra man i2 anu pang replacement sa ganito? Tnx
Saan iyang C144? Anong Part No.?
Post by geof79 on Sat Nov 25, 2017 12:04 am
Sir hertz, part # Q808 pag lagpas ng opto coupler. Karatig lng ng 431 transistor.
geof79
Post by geof79 on Mon Nov 27, 2017 5:56 pm
Ok na i2 pgkbit ko ng board. Buo pa rin pla vertical. Pnalitan ko lng ng power regulator taz un 3 ecap na lumubo sa sec0ndary. Halos karamihan lng na tikal sa pgkasulda.
geof79
Post by triac on Wed Nov 29, 2017 5:10 pm
congratz sis geof79.
Post by geof79 on Tue Jan 16, 2018 5:22 pm
Ask ko lng my ibang output ba na pwd pamalit sa D5024?
geof79
Post by geof79 on Tue Jan 16, 2018 5:23 pm
Need ko lng i2 sa ibng tv na gani2 din ang parts. Wla kc ako mbili.
geof79
Post by ultrasonic™ on Fri Jan 19, 2018 11:17 am
Lagyan mo kahit D1555... pwede na dyan
Post by triac on Mon Jan 22, 2018 10:57 am
basa mode lang mga sis..andito na pala si sir ultra...
Post by geof79 on Thu Jan 25, 2018 12:44 pm
Tnx sir ultra. My naipalit na ako pareho #. Buti nrin un alam ko kung anu ibng pwd ipalit. Sa sun0d na mangailangan mdali ng mkahanap. Update ko nrin d2 un sa unit na gnawa ko. Pg power my pr0b pa sa screen kc d buo. Tg kbilang gilid my itim na 2 inch. Check ko ng yoke ok nman. D ko pa mhuli kung saan cra sa board.
geof79
Post by ultrasonic™ on Thu Jan 25, 2018 10:23 pm
width cap.. try mo palitan o hilutin mo..
puede rin hilutin sa Smode
Post by geof79 on Sat Feb 17, 2018 12:13 pm
Tnx sir. Panu ba mpadisplay ang smode. D ko pa kc alam sa tcl. Sa ibng brand lng alam ko. Ngaun lng nkpg ol subrang bc sa mga gawain.
geof79
Post by Hertz on Sun Feb 18, 2018 10:55 pm
Subukan mo ito geof79
1.1. The way to enter P-Mode
a) Method one
A) Switch on the TV set.
B) Press the “MENU” key on RC to show the “PICTURE” OSD menu.
C) Move the cursor to “Contrast” item then press the “9”, “7”, “3”, “5” key
continuously on RC within 3 seconds then enter P-Mode. The “P” letter will
appear on the left low corner of the screen when enter P-Mode. Also the
“FACTORY HOTKEY” will be set to “ON (= 1)”.
b) Another method
Press the “RECALL” key on RC to enter P-mode directly.
Note:
1. This will be active only when the “FACTORY HOTKEY” had set to “ON (= 1)”.
2. When the power on with “FACTORY HOTKEY” had set to “ON (= 1)”, the set
will enter the P-Mode automatically.
1.2. Exit the P-Mode
Press the “RECALL” or “MENU” key on RC to exit the P-Mode.
1.3. Keys’ function on RC at the P-Mode
Use the RC to navigate in P-Mode:
Press “0” or “AT” key for screen voltage adjustment.
Press “1” to “8” and “FAV” key to select factory adjustment page.
Press “9” key to switch the I2C bus off/on.
Press “▲▼” or “CH+ CH-”key to select option.
Press “►◄” or “VOL+ VOL-” key to adjust or select option.
Press “DISPLAY” key to display software version.
Press “MENU” key to close the factory menu or return to the previous menu or exit
the P-Mode.
Press “RECALL” key to enter or exit the P-Mode.
Note: All change in P-Mode will be saved in EEPROM automatically.
Post by triac on Tue Feb 20, 2018 9:16 am
and dami ng option binigay ni sir hertz. Very Happy
Post by geof79 on Fri Feb 23, 2018 5:16 pm
Tnx sir hertz sa info. Dagdag kaalaman.
geof79
