TOSHIBA - HAY-22 COLOR TV IT - USING TDA8893IC AS SYSTEM CONTROL-VIDEO-CHROMA - SERVICE MODE & ADJUSTMENTS
Post by Hertz on Fri May 12, 2017 10:55 pm
TO ENTER SERVICE MODE [FACTORY MODE] Press ‘Menu Up’ and dial 6483 by remote control. Factory mode screen will be displayed. Use ‘1 & 4’ keys to adjust R-Cut, ‘2&5’ keys to adjust G-Cut and ‘3&6’ keys to adjust Blue-Cut. To exit service mode, press ‘Mute’ button on remote control.At the second time, press ‘Display’ key to get F1 mode. Press ‘Ch + and Ch-‘ key to select an item, and press ‘Volu + and Vol-‘ keys to change the data value to selected item. Press ‘Display’ key to exit from factory menu.
TOSHIBA HAY-22
