Daewoo Tv ( Chassis CN-794N ) Eboard: 4859816791-01 Elektra
Post by ultrasonic™ on Sat Oct 08, 2016 11:11 am
DAEWOO TV
DTQ-29U1SS
DTQ-29U5SC/SS
Chassis CN-794N
Reg: MR2540
EEPROM: 24LC16B
System Con: LC863856A-51S2
Jungle: VDP3130Y
Sound Procie: MSP3420G B8 V3
RGB: TEA5101B
Sound: TDA8946J
Vert: LA7848
Hot: 2SD2578
FBT: FFA94048L
Tuner: 115-V-F025AR
FBT FFA94048L
pin1  - COL
pin2  - B+ / +132V
pin3  - Video 200V
pin4  - 10V
pin5  - N.C
pin6  - 27V
pin7  - GND
pin8  - ABL
pin9  - Heater
pin10 - AFC
1) How to enter the service mode using the user remote control.
• Turn the set on.
• Direct the remote control to the reception window of TV.
• Push buttons of remote control in sequence as follows.
1 + MUTE + DISPLAY + MUTE
• Then, the screen will appear as follows.
• Using the channel up or channel down button, select the item you wish to adjust.
(The color of selected item turns into the red.)
• Press the volume up or down button to enter in the service mode you wish to adjust.
2) How to memorize the adjusted values in the service mode.
• Must press DISPLAY button the state which the screen is displaying each of service menus
after all adjustments are completed each of all service menu.
Daewoo TV Chassis CN-794N
