6 Channel Disco Running Lights 5 5 1
Post by mayalin143 on Wed Dec 15, 2010 3:00 pm
From 230 V AC a DC supply of + 5 V is obtained. The power supply is given to the other blocks. The pulse generator at a particular frequency generates the clock pulses. The clock pulses are counted by a counter and gives output after every 10 pulses. The counter drives the transistors, which form the triac firing circuit. The transistors fire the triacs and they provide sufficient current to the load. Decorative bulbs are connected as load for each triac. The bulbs are sequentially turned ON and OFF in forward and reverse way.
The IC 555 works as the pulse generator and feeds the clock pulses to IC 4017. IC 4017 is the heart of this circuit. It works as a counter and gives the output after every 10 pulses. It drives the transistors, which in turn fire the triacs. The triac provides sufficient current to the load.
Parts:
R1 - 47 KW
R2 - 100 KW Potentiometer
R3 - 56 W
R4, R9 - 8.2 KW
R10,R15 - 47 W
C 1 - 1000m, 16 V Electrolytic
C 2 - 1m, 16 V Electrolytic
C 3 - 0.01m Ceramic
D1, D2 - IN 4007
D3, D10 - IN 4148
D 11, D16 - LED, Red color, 5mm
T 1, T 6 - BEL 187, NPN Transistor
T 7, T 12 - BT 136, 4A/400V
IC 1 - 7805, Voltage regulator
IC 2 - 555, Timer IC
IC3 - 4017, Decade counter
Switch(S1) - 1 Pole 6 way
Transformer(T) - 230 V / 9V, 500mA
F 1, F 2 - Fuse
All resistors are carbon composition type of
mayalin143
Re: 6 Channel Disco Running Lights
Post by Back2Basic on Tue Sep 27, 2011 5:26 am
ate meron po bang schematic diagram to or picture? or d ko lang maview? pls reply...thanks..
Back2Basic
Post by mayalin143 on Fri Oct 07, 2011 6:18 pm
ang daya mo kuya. mas matanda ka pa sa akin. wag mo kong tawaging ate Crying or Very sad
ito po iyong diagram
mayalin143
Post by zandertech on Tue Nov 15, 2011 12:40 am
parang putol ung diagram miss ganda,... doubt
Post by mayalin143 on Wed Nov 16, 2011 5:38 pm
putol lang po siya dahil di nagkasiya sa forum size. save as niyo na lang po ang image ng makita ng buo.
mayalin143
Post by zandertech on Wed Nov 16, 2011 7:44 pm
ah ok na miss ganun lng pla thanks., apologies
