ATX power supply unit repair
Post by gatorade on Sat Apr 09, 2016 5:44 pm
mga sir tanong ko lng po,pano po itroubleshoot ang atx powersupply ng pc ko.bigla nlng namaty pc ko,chineck psu pinagconnect green &black wire wlang output.ok nmn fuse,220v sa primary rectifier may voltage din ang primary caps.walang standbyV sa green and violet wire.ndi nmn bulky ang ecaps.thanks mga master
gatorade
Re: ATX power supply unit repair
Post by Electro on Wed Apr 13, 2016 8:06 pm
check mo ang dual diode master na kamukha ng transistor o regulator ic na 7805. baka shorted yan master. madalas yan sa atx supply na nasisira
Post by DJFEL on Fri Oct 21, 2016 1:36 pm
nasa primary suply sire..
