sony projection tv pa help po
Post by batmantech on Tue Mar 22, 2016 1:41 pm
serial number FW46M91 MODEL SONY PA HELP po walang lumalabas na picture o liwanag tapos after a second mamamatay na ulit nag biblink siya ...
Re: sony projection tv pa help po
Post by Electro on Tue Mar 22, 2016 2:21 pm
check mo ang voltage out niya master baka may nawawala
Post by alvinquimbo on Tue Mar 22, 2016 6:56 pm
baka may heavy loads yan sis kaya nagpropotic...sundan mo payo ni sis electro sis..
Post by batmantech on Wed Mar 23, 2016 7:48 am
Post by Oscar on Sat Mar 26, 2016 9:41 pm
bilangin mo ang blinking code niya master
Post by batmantech on Mon Apr 04, 2016 8:43 am
10 ang blinking niya ...
Post by Hertz on Mon Apr 04, 2016 5:51 pm
double check mo ang pagbilang
kung sampo nga iyan, marami sakop iyan pwede may problema ka sa digital board o tuner
Post by batmantech on Mon May 02, 2016 3:34 pm
nahirapan ako shorted yung board may na solda may nag ka dikitan na line sa board ,,,, nasisid ko palang .. buti hindi sumabog
Post by alvinquimbo on Tue May 03, 2016 9:03 pm
update mo kami sis kung anong resulta na yan...abang mode muna kami...
Post by ultrasonic™ on Thu May 05, 2016 11:02 am
error codes yan.. pag ganyan wag magtiwala sa code. Go on deep checking. mas kutob ko balikan mo ang vertical section siraan yan sa mga ganyang model. pero unahin mo muna ang mga Test point supply ng SMPS board
Post by Hertz on Thu May 05, 2016 3:46 pm
batmantech wrote:nahirapan ako shorted yung board may na solda may nag ka dikitan na line sa board ,,,, nasisid ko palang .. buti hindi sumabog
 resulbahin mo muna yan at baka yan lang ang problema
Post by alvinquimbo on Thu May 05, 2016 10:42 pm
@sir hertz and sir ultra..kumusta po kayo???welcome back po..
Post by sherlanmamaril on Thu May 05, 2016 11:02 pm
katakot ang projection , masters punta kayu dito may lg din ako na tv projection lakas ng loob ko dahil sa mapa meron ako
Post by volter on Fri May 06, 2016 12:57 pm
may gumagamit pa pala niyan ngayon?
4th member of STTM
former 5th member
volter
Post by Electro on Sat May 07, 2016 5:46 pm
nakakamiss kayo master Crying or Very sad
Post by ultrasonic™ on Thu May 12, 2016 9:52 pm
@sherlan gawan mo ng thread. try natin ayusin
@Sir Volter.. iilan lng ang gumagamit nyan.
@jeff.. ^_^ miss ko din kau
@vin.. Ok lng... kahit bz
Post by sherlanmamaril on Sun May 22, 2016 8:08 pm
sige nga master , kasi ngayun nakatambak to sayang naman po talagang failure ko eh sensya nd ako madalas dito master
Post by alvinquimbo on Fri May 27, 2016 6:30 pm
sis..wag ka mawalan ng pag-asa..makakaya yan...tiwala lang tayo sa sarili natin.. nandyan naman ang mga master natin na handang tumulong...
Post by Electro on Sat May 28, 2016 10:12 pm
Sang ayon ako sayo master
Post by alvinquimbo on Sat Jun 04, 2016 7:13 pm
approved approved approved
Post by sherlanmamaril on Sat Jun 04, 2016 11:37 pm
abang mode,  :0
Post by batmantech on Mon Jun 27, 2016 12:19 pm
hindi na pinaayus pero nabuhay kuna yung tv.... patay sindi patay sindi ko lang yung tv tapos biglang nag karoon ng ilaw yun gumana na
Post by Hertz on Tue Jun 28, 2016 11:01 pm
baka may loose connection lng o hindi kaya intermittent problem na pyesa
Post by Electro on Fri Jul 08, 2016 9:33 pm
baka may loose con lang master. Sayang nahuli mo sna ang sira para may reference tayo
