Sharp 21" DUNTK9428WE
Post by geof79 on Tue Sep 08, 2015 1:51 pm
Pa help mga master. My nsun0g e2 resistor papunta sa crt board. D ko na mkuha kung anung value. R454 sa pgitan ng tuner at flyback. Ang parts ng tv
REGULAtor-D1884
HOT-D2586
VERTICAL-TA8403K
audio-TDA7056A
geof79
Re: Sharp 21" DUNTK9428WE
Post by geof79 on Tue Sep 08, 2015 3:22 pm
Bka my alam nman neto mga master, need ko lng kc ngaun kung an0ng value. Wla kc b0ard na ka m0del. Thankz..
geof79
geof79
Post by Hertz on Tue Sep 08, 2015 6:02 pm
L2 chassis iyan. - link
Post by geof79 on Tue Sep 08, 2015 6:47 pm
Ok na sir hertz, thanks. nkuha ko na un value ng nsun0g. Prob neto kc dati kulay pink nlang display, taz now saglit lang na on tpos balik na sa standby. Ng open un R454 at R458. Nag check na ako ng suply sa vertical pero wla. Try ko na replace.
geof79
Post by Hertz on Tue Sep 08, 2015 9:08 pm
kong pink ang kulay maaaring patay ang green. subukan rin magreprogram ng eeprom.
Post by geof79 on Wed Sep 09, 2015 12:12 pm
Pki tama lng mga master kung mali ako. R511 - 1 ohm? Mejo mlabo na kc un kulay ng resistor. Galing Pin 7 ng fbt punta ng TA8403K.
geof79
Post by Hertz on Wed Sep 09, 2015 12:51 pm
1.5 ohm 1/2w pero pwede na rin iyang 1 ohm. fuseable lang naman ang silbi niya sa board
Post by geof79 on Wed Sep 09, 2015 1:02 pm
Slamat sir hertz. Ask ko lng kung panu mgtest ng board kung ok na. Pwd ba i2 kht wlang yoke taz d na nka hang un HOT?
geof79
Post by Hertz on Wed Sep 09, 2015 1:10 pm
yes pwede iyan. basta ok ang b+ mo at tama ang oscillation. 115v-125v
 na B+ ay ok sa ganyang board
Post by geof79 on Wed Sep 09, 2015 1:19 pm
Ok sir hertz. Tnx..
geof79
Post by Hertz on Wed Sep 09, 2015 1:21 pm
basta 125 ang standby mo at bagsak namn kunti pag nag oscillate
Post by geof79 on Wed Sep 09, 2015 1:35 pm
San ko ba msu2kat un 125 sir? Ntest lng ako sa colector ng HOT. D ko pa kc kbsado.
geof79
Post by geof79 on Wed Sep 09, 2015 2:59 pm
Ask ko nrin i2 mga master. Kung nka hang ba ang HOT wla tlga nsu2kat na voltage sa mga diode galing sa pin ng fbt? Ganun din sa vertical? O my iba pang prob pg gnito? Sa tuner meron lng ay un 33v taz ung 5v wla rin. Meron nman 5v sa pin ng remote sensor. Sa colector ng HOT 125v ang nasukat ko.
geof79
Post by Hertz on Wed Sep 09, 2015 4:51 pm
pagtinanggal mo ang H-out, sadyang wala ka ngang masusukat sa mga output ng flyback. hanggat walang oscillation ay wala talaga yan.
Post by geof79 on Wed Sep 09, 2015 5:07 pm
Ah, ok mlinaw na skn. Ibig sbhn patay din un supply ng vertical kc galing din sa fbt? Ng replace na ako ng vertical ne2 kc my tama. Ng open nga rin un fuse resistor. Update ko nlng i2 pg naikabit na un b0ard. Tnx sa reply sir hertz.
geof79
Post by Hertz on Wed Sep 09, 2015 5:43 pm
your welcome. goodluck sa inaayos mo
Post by geof79 on Sat Sep 12, 2015 9:25 am
Ok na e2 master. Pgkbit ko my kunti prob pa. My mga loose lng pla sa pin ng jungle ic. Dagdag ktanungan lng, san ba maari prob ng tv pg my shadow na color? Minsan pa kumakalat.
geof79
Post by Hertz on Sat Sep 12, 2015 9:49 am
anong klaseng shadow? puede bakat yan ng degaussing o may problema ang crt socket
Post by geof79 on Sat Sep 12, 2015 7:32 pm
Un sir halimbawa sa mukha ng tao sa display my lumilitaw sa gilid na kulay blue.
geof79
Post by Hertz on Wed Sep 16, 2015 9:37 am
fading effect. pwede mahina ang video supply. palit ka na rin ng caps niya. pag walang pinagbago ay palit ka ng bagong crt socket.
Post by geof79 on Mon Sep 21, 2015 10:13 am
Tnx d2 sir hertz. Ok na ang unit. Cnundan ko lng advice nyo. +1 sau sir.
geof79
Post by Hertz on Wed Sep 30, 2015 10:16 am
mabuti naman. congrats
Post by DJFEL on Wed Oct 07, 2015 9:44 pm
nka protic to..kolang yata supply patongo nang CRT bord..
Post by alvinquimbo on Wed Oct 07, 2015 11:11 pm
congratulation congratulation congratulation
