(chassis)th-2128c sinu po may diagram neto
Post by daredevil on Sun May 24, 2015 2:57 pm
sino po may diagram ng model na ito astron na 14 inches need diagram badly sunog mga resistor sa power supply need help please thanks sa master natin jan Smile
daredevil
Re: (chassis)th-2128c sinu po may diagram neto
Post by Hertz on Tue May 26, 2015 9:49 pm
check mo iyong mga china model na gumagamit ng 76931 halos pareho lang ang mga yan
Post by dizon on Sat May 30, 2015 9:26 am
parang si master electro may extrang board na ganyan. post niyo na lang master ang resistor na kailangan niyong malaman. para kong sakali mapadaan siya master
dizon
Post by daredevil on Tue Jun 02, 2015 10:48 am
maraming salamat mga master Smile
daredevil
Post by Electro on Thu Jun 04, 2015 1:04 pm
meron nga ako niyan master. post mo lang kailangan mong value
Post by daredevil on Sat Jun 06, 2015 2:50 pm
eto po need ko malaman mga master R524=? R525=?
pati po yung regulator V512 and V503 thanks po master electro Smile
daredevil
Post by Electro on Sun Jun 07, 2015 10:12 pm
master, TN6R04 ba ang regulator niya. yun may 5 pins?
V503 : TN6R04
R510 : vacant slot
R511 : vacant slot
R513 : vacant slot
R514 : jumper
R515 : Vacant slot
R517 : 10K 1/8W
R519 : 100R 1/4W
R520 : 650K 1/2W
R520A: vacant slot
R521: 650K 1/2W
R523 : 100R 1/8W
R524 : vacant slot
R525 : 47K 3W
R528 : vacant slot
R530 : vacant slot
R552 : 100K 1/2W
R553 : 5.6K 1/4W
R554 : 150K 1/4W
R555 : 47K 1/4W
R556 : 22K 1/8W
R718 : 100R 3W
RP551: 2K trimmer
W504 : jumper
W505 : jumper
W506 : jumper
W507 : 103M 2KV
W508 : vacant slot
V511 : vacant slot
V512 : jumper sa + at center leg
V553 : C1815
VD514: vacant slot
VD516 : jumper
VD517 : vacant slot
VD518 : jumper
VD519 : jumper
C513 : 100uf 400V
C514 : 2A123J mylar
C515 : vacant slot
C517 : 472J 100V brown cap
C518 : vacant slot
C520 : 471 2kV blue cap
C521 : vacant slot
C522 : vacant slot
C523 : 2A822J mylar
C524 : 102J mylar
R526 : 471 ceramic
C526 : jumper
C566 : 222
C569 : vacant slot
N502 : 817 opto
Post by daredevil on Mon Jun 08, 2015 1:45 pm
transistorize po sya master electro anyway pinalitan ko po ng ST8812 under observation na po sya master electro thank you na rin po Smile
daredevil
Post by Electro on Mon Jun 08, 2015 10:51 pm
transistorize pala master. ito ang listahan namin niyan master
V503 : ST8812FX
R3 : vacant slot
R510 : vacant slot
R511 : 5.6K 1/8W
R513 : vacant slot
R514 : jumper
R515 : 22K 1/8W
R517 : 1K 1/8W
R519 : 22R 1/8W
R520 : 120K 1/2W
R520A: vacant slot
R521 : 120K 1/2W
R522 : 15K 1/8W
R523 : 3.3K 1/8W
R524 : 61R 3W
R525 : 61R 3W
R526 : 2.2K 1/8W
R528 : vacant slot
R530 : vacant slot
R552 : 100K 1/2W
R553 : 5.6K 1/4W
R554 : 150K 1/4W
R555 : 47K 1W
R556 : 22K 1/8W
R580 : vacant slot
R718 : 10K 3W
RP551: 2K trimmer
W504 : jumper
W505 : jumper
W506 : jumper
W507 : vacant slot
W508 : vacant slot
W509 : jumper
V511 : C1815 transistor
V512 : C2655 transistor
V553 : C1815
VD514: zener/signal diode ?
VD515: vacant slot
VD516 : zener/signal diode ?
VD517 : HV diode ?
VD518 : zener/signal diode ?
VD519 : zener/signal diode ?
VD521: vacant slot
C507 : 100uf/400V
C513 : 2A472J mylar
C513A: vacant slot
C514 : 104J 100V mylar
C515 : 153J 100V brown cap
C516 : 681 2KV blue cap
C517 : 153J 100V brown cap
C518 : vacant slot
C520 : 47 2kV blue cap
C521 : vacant slot
C522 : vacant slot
C523 : vacant slot
C524 : vacant slot
C526 : vacant slot
C531 : vacant slot
C534 : vacant slot
C566 : vacant slot
C569 : vacant slot
N502 : PC817 opto
2A222J connected from R523 to R527
mga value ng diode ay tanong niyo na lang kay master ultra
Post by daredevil on Wed Jun 10, 2015 11:36 am
thank you so much master electro nakatulong ng malaki sa akin ito Smile
daredevil
Post by Electro on Fri Jun 12, 2015 2:13 pm
walang ano man master. mas nagagalak akong makatulong
Post by triac on Tue Jun 16, 2015 5:38 pm
basa mode... reading
