JVC 21 INCHES MUSEE DEADSET
Post by daredevil on Sun Apr 19, 2015 3:38 pm
PATULONG NAMAN PO 000000][/color] SA MGA MASTER JAN DEADSET PO JVC WALANG ILAW YUNG POWER NAGPALIT NA AKO NG REGULATOR WALA PA RIN NANGYARI DI PO NAKAKALABAS YUNG KURYENTE SA FILTER CAPACITOR ...THANKS PO IN ADVANCE SA MGA MASTER JAN ....STR W6756 PO ANG REGULATOR NYA MAY POWER ITO BAGO KO ITABI TAZ NUNG KUKUNIN NA NG MAY ARI BIGLANG AYAW NA UMILAW PATI YUNG LED  POWER DI RIN NAILAW...NEED IT BADLY THANKS...
daredevil
Re: JVC 21 INCHES MUSEE DEADSET
Post by Hertz on Tue Apr 21, 2015 12:03 pm
next time. iwasan sana mag caps lock
check mo baka may nag open na resistor malapit sa main regulator str
Post by daredevil on Thu Apr 23, 2015 2:34 pm
thanks sa paalala master hertz nacheck ko na po lahat ng resistor ok naman po....
daredevil
Post by daredevil on Sat Apr 25, 2015 11:26 am
baka meron naman po nakaencounter sa inyo nitong trouble na to (cw3 chassis po ) nacheck ko na lahat ng resistor pinalitan ko rin ng regulator (str w6756) di po talaga nakakalabas yung kuryente sa filter capacitor taz walang ilaw yung power led nya pahelp naman po sa naka encounter na ng ganitong trouble thanks in advance....
daredevil
Post by Hertz on Sat Apr 25, 2015 1:57 pm
buo ba ang h-out mo? baka di nag oscillate ang regulator mo kaya wala kang b+. may stock ba ang primary cap?
Post by daredevil on Sat Apr 25, 2015 3:28 pm
buo po horiz out yung primary filter capacitor di naaalis ang charge kaya di makatawid ang kuryente nasa primary filter capacitor lang po master hertz lahat ng posibleng problem sa regulator na mga resistor nacheck ko na pero wala pa rin po ....
daredevil
Post by Hertz on Sat Apr 25, 2015 4:20 pm
hindi nga gumagana ang regulator mo niyan. check mo baka may leak diodes sa primary side o leak capacitor kaya hindi magtuloy ang regulator. check mo rin ang PC901
Post by daredevil on Sat Apr 25, 2015 5:22 pm
pinalitan ko na din pc901 cge po master check ko for leaky diode and ilan lang capacitor neto na maliliit cgura actual replacement ko na lang feedback na lang po ulit ako thanks Smile
daredevil
Post by Hertz on Sun Apr 26, 2015 10:09 am
check mo rin ang mga high resistance na resistor
Post by daredevil on Tue May 05, 2015 11:52 am
Thanks Master Hertz at sa lahat ng tumulong solve na deadset may leak na zener diode kaso nag spark yung flyback kahit walang butas kaya bigla ring nawawala picture kapag nag spark sa flyback any idea?....
daredevil
Post by alvinquimbo on Tue May 05, 2015 8:35 pm
sis baka may malilit na butas yan sa HV wire nya..check mo maigi or try mo paandarin sa madilim na lugar ng makita mo ang arching nya..or linis mode ka, alisin mo ang mga carbon sa tube na magcacause ng arching..kung wala parin ay check mo oscillation nya baka mataas..gamit ka ng light bulb trick ng mamonitor mo ito..hope makatulong to sayo sis..
Post by Hertz on Tue May 05, 2015 10:31 pm
pag may butas ay isolate mo muna ang HV
Post by Electro on Fri May 08, 2015 10:30 am
pagwalang arching ang flyback master. pwed mataas ang oscillation niyan master
Post by daredevil on Sat May 09, 2015 8:56 am
salamat mga master sa share na kaalaman binalot ko na lang ng electrical tape ayun nawala yung arking observe ko pa.... input voltage ng horiz section is nasa 120vdc normal naman Smile (y)
daredevil
Post by daredevil on Sat May 09, 2015 8:58 am
@Master alvin anu po yung lightbulb trick? panu procedure?.....
daredevil
Post by alvinquimbo on Sun May 10, 2015 9:16 am
Punta ka dito sis...malaki ang maitutulong yan sayo..
http://aelexian.4rumer.com/t132p90-troubleshooting-guidelines#14731
Post by daredevil on Sun May 10, 2015 11:26 am
thanks master alvin +1 ka Smile
daredevil
Post by Electro on Mon May 11, 2015 1:50 pm
sa hv wire lang pala ang tagas master daredevil. pwede na yang electrical tape. higpitan mo lang masyado ang kapit. tapos obserbahan mo ng ilang oras ang tv
Post by daredevil on Tue May 12, 2015 10:03 am
Yup Master Electro ok napo thanks sa tulong nyong lahat Smile thums up
daredevil
Post by Hertz on Tue May 12, 2015 10:22 am
congrats
Post by Electro on Wed May 13, 2015 3:53 pm
ok na pala. congrats master
