Panasonic th-15fr5
Panasonic th-15fr5
Post by Emorej6 on Thu Sep 18, 2014 6:50 am
,ano po kaya pang sub dito ?
437c ,ung chip ic ,7 pin po un .Gnagamit sya dun sa secondary shorted kc kya ayaw mag gumana ng relay .,my nbibilhan po kaya nyan ? Kht png sub or kht emodify nalang ,pwede po kaya ? Sa tingin ko transistor lng yan na pnagsama sama ..
Jungle=tb1253dn
system=mn1873287ts
fbt=ztfn32004a
h out c5622
Emorej6
Re: Panasonic th-15fr5
Post by Electro on Thu Sep 18, 2014 10:49 am
hindi familiar sakin yan master. ano po hitsura niya? di kaya zener yan master?
ano pala chassis niyan master?
Post by Emorej6 on Thu Sep 18, 2014 5:31 pm
,hndi ko po nakupya ang chassis e home service po kc. ,para po syang chip memory ,kaso 7 pin lng .Bali 8 pin dn sya pnagsama lng ung 2 ...
Emorej6
Post by Electro on Fri Sep 19, 2014 12:24 pm
hindi kaya yan iyong dual regulator master? 5v at 9v na pinagsama. Ano pala ang main regulator niya master? titext ko sana si master ultra kong alam niya ito
Post by Emorej6 on Sat Sep 20, 2014 5:58 am
,hindi ko dn po nakupya ang regulator ..Hindi dn po eto master pnagsamang 5v,9v regulator ,d2 po yata galing ung sa relay .,connected po sya sa mga diode na papunta sa supply lng relay .,ang problema kc ng unit bali 2 ung relay nya sa psu ayaw mag on .At wala dn supplya ang memory ,5v,9v, ,at nkta ko shorted ung ic na un ,tapos buntis ung katabing ecaps..,,parang 3pin or 4pin lng po ung ginamit na pin dun sa ic.
Emorej6
Post by Electro on Sat Sep 20, 2014 3:38 pm
master ano magyayari ko pinagshort niyo ang contact ng relay sa power?
Post by Emorej6 on Sat Sep 20, 2014 10:35 pm
,master bka pg nejumper ang relay my maapektuhan na iba ,kc pg surplus na tv hndi ako nag jujumper ng relay nasabog kc main filter capacitor ..,110v kc ung tv convert lng sa 220v
Emorej6
Post by baddypepito on Mon Sep 22, 2014 10:07 am
huwag po ijumper sis.. best way jan ay palitan yong defective na part.. try mo lang igoogle kung meron bang datasheet..
Post by Electro on Mon Sep 22, 2014 12:03 pm
check niyo muna master. pag ok lahat bago jumper. yan kasi madalas kong gawa. minsan nakakatulong ang mga sumasabog na parts. madaling matukoy na sira na pala sila. ito po ay sarili ko lang pong openyon. alam kong mali. pero nakakatulong din minsan
Post by triac on Tue Sep 23, 2014 6:57 pm
basa mode..
Post by Emorej6 on Wed Sep 24, 2014 11:54 am
,,nd ko po mahaharap ung unit asa batangas kc un andto ako sa mindoro.
Emorej6
