pa help! SHARP (DUNTKC522WE) stand-by only..
AELEXIAN EMPIRE :: Analog and Mixed Signal Device Repair (Electronics Technician Board) :: (Electronics Technician Board) :: Television Repair
Page 1 of 1 • Share •
A]MERON PO AKONG GINAGAWA STAND BY LNG. NEED PO NG ADVICE MGA MASTER.
tonzkie08- AAA Battery
Re: pa help! SHARP (DUNTKC522WE) stand-by only..
DEAD SET PO UNG TV TPOS PINALITAN KO NG REGULATOR, NAGKARON NG STAND BY LIGHT PERO AYAW MAG ON. ANO PO GGWIN KO MGA MASTER? SHARP DUNTKC522WE.
master download ka ng diagram
may post si master nyan
http://aelexian.4rumer.com/t1251-sharp-tv-chassis-ga-4-1w-eboard-duntkc522we
Electro- D Battery
ok ba ang h-out mo master? umabot ba ang B+ supply?
may na 9v na ba kayo sa jungle?
Electro- D Battery
meron po master. knina deadset to tpos pinalitan ko ng strw6753 nagkaron ng stand by pero ayaw mag on.. meron nman 9v at 5v master buo din h-out.
mga master advice pa po.. tnx
check mo tact switch sir kong may continuity
vintot26- AAA Battery
@sis tonzkie08 kung naka stand by yan,pakisunod si sis electro kung may B+ ba o wala..tapos observe mo yung boltahe ng primary ecaps when plug and unplug?Kasi pag naka unplug yung unit mo at may nasusukat kang mataas na volts sa primary,ibig sabihin di pa gumagana si regulator,bale may mga periherals parts jan sa PSU mo ang pumipigil nadi gumana sire gulator mo kaya suyurin mo lahat ng peripheral parts ng regulator..
alvinquimbo- D Battery
@ts..sinubukan mo bang i power sa remote?or press chanel boton,baka sakali lng na hindi
arkin- D Battery
tama si master arkin. baka hindi napindot ang secondary power
Electro- D Battery
ok nman khat ng tact switch mga master.. meron b+, minsan nag ki-click ung relay tpos after 3 seconds namamatay ulit. meron din akong nasusukat 24v sa vertical kpag pinindot ko ung power switch..tumawid na sa secondary ung voltage nya.. kelangan nlng mag-oscillate nito mga master...
,,my supply b relay nyan master?? ,san ba patungo ang relay nyan ,para ba sa deguasing ?? ,try mu kaya ehang ang pin 8 ng memory ? ?Bka sakali ..
Emorej6- AA Battery
na check mo na lahat ng mga zener diode master?
Electro- D Battery
susubukan ko mga master.. meron na akong na hang na mga zener diode pero wla parin..
,iwasan mu maghang ng zenner diode ..Dilikado yan dadame lalo cra nyan kc ang zenner ai nag reregulate ng voltage .
Emorej6- AA Battery
baka walang supply sa hdt master? subukan mo kaya master magpalit ng vertical ic. reset na rin ng memory
Electro- D Battery
flat ba ito sis.? kung flat. try to check o replace muna ang kanyang yoke for testing purpose only.. sa tingin ko kc.. parang nagoscillate na xa,. kaya lang ngshushutdown after 3 seconds..
bali voltage ka po muna.. check lahat ng voltages sa secondary.. sa tingin ko. free na ang primary side nito..
baddypepito- C Battery
kumusta na ito master?
Electro- D Battery
abang mode muna..
ok na ung primry nito for sure mga master pero shut-down tlga after 3 to five seconds.. try ko muna magpalit ng vertical.. meron din nag advice skin na magpalit ako ng jungle i.c.. any suggestion pa po mga master..
,pag ba nkahung b+ ? Ilang volts??
Emorej6- AA Battery
oo nga master tonzkie. ilang b+ niyo?
Electro- D Battery
add more info.. ano na ang mga nagawa mo?
ultrasonicâ„¢- D Battery
Suggest lng, my nagawa kc ako pag on nun tv sec0nds lng na off ang relay taz d npower. Nkuha ko cra capactor mlapit sa relay swtch, un 2l0y na pag power nun tv.
geof79- D Battery
Page 1 of 1
