PA help po TCL problem standby only
Post by batmantech on Sun May 11, 2014 4:28 pm
pa help po mga master about po dito sa inaayus kung tv tcl po yung brand niya model 14175 chasis number:40-2111sg ang problema po nito yung naka standby lang po siya dati po kasi ganito rin yan tapos nakuha kung sira eh yung remote niya di naayus na po yung remote gumana siya after that pag ka umaga di na po nag on naka standby nalang po siya
first check up na ginawa ko tinest ko po yung horizontal outpot niya tapos sunod yung regulator niya ayus po siya pareho
saan po kya sira nito ?
Re: PA help po TCL problem standby only
Post by Electro on Mon May 12, 2014 10:51 am
reset mo ang memory master baka uubra. hinang mo ang pin 8. pag walay pagbag-o. reprogram ka na master
Post by batmantech on Mon May 12, 2014 3:32 pm
pano ireprogram master?
Post by ultrasonic™ on Tue May 13, 2014 2:39 pm
hmmpff. dhil tcl yan ay mkikiagree ako ky jeff....
kong ayaw makuha sa hard reset ay go ka na nga sa reprogram
my DIY serial programmer tau dito sis batman..
try mo silipin dito ->
http://aelexian.4rumer.com/t473-diy-eeprom-programmer-kit-serial-version-by-seph-pete-ng-elab
nandito nmn ang e2p files nya.. ->
http://aelexian.4rumer.com/t774-master-list-_
Post by batmantech on Tue May 13, 2014 4:31 pm
sir ultra pwede bang gamitin ang horizontal outpot na D 1651 kasi po nasira po yung D1555 tapos po update po napa gana kuna kaso po yung channel niya po walang signal saan kaya po ito ?\
Post by alvinquimbo on Tue May 13, 2014 10:51 pm
@batmantech,try mu check ang supply ng tuner mu kung kumpleto or di kaya resoder mu yung loob ng tuner..sana makatulong kahit konti..
Post by ultrasonic™ on Wed May 14, 2014 1:42 pm
@sis batmantech.. yapz pwdeng pwde yan.. any H-out pwde bastat my internal damper diode.. pkiramdaman mo lng ang body nya kng mabilis ba xang uminit.. pg mabils at di kayang hawakan ng kamay ay palitan mo ng mas mataas na specs..
Post by ultrasonic™ on Wed May 14, 2014 2:24 pm
sundan mo din ang advice ni sis alvin.. dpat my 33V, 12/9V at 5V ka jang masukat
Post by batmantech on Fri May 16, 2014 5:31 pm
kuha na sir thank you sa lahat .,., resolder ko lang po yung tuner niya sa loob thank you sa lahat
Post by Hertz on Sat May 17, 2014 11:17 am
congratulations
Post by Oscar on Wed May 21, 2014 6:13 pm
congrats master
