Help! Sanyo 21 no raster but audio ok
Post by Lenaren on Mon Dec 16, 2013 5:36 pm
Patulong master walang raster pero ok ung audio.... nagpalit na me capacitor sa vertical at bago na rin ang vertical ic... pag taasan ko g2 horizontal line lng.. medyo garalgal din tunog ng audio nya...
thanks
Re: Help! Sanyo 21 no raster but audio ok
Post by Hertz on Mon Dec 16, 2013 6:02 pm
model pls
Post by Lenaren on Mon Dec 16, 2013 6:40 pm
sanyo avm 21v m8 master.....
Post by ultrasonic™ on Tue Dec 17, 2013 12:20 pm
unahin mo muna ang H.line nya sis.. check mo ang mga supply ng vertical ic... pg kumpleto sunod mo nmn ang yoke.. change na rin ng secondary filter caps baka palyado kaya my effect sa audio...
Post by ultrasonic™ on Tue Dec 17, 2013 12:29 pm
try mo tong manual na to sis... bka makatulong sa pag titrace
Chassis M17
pa cnfirm na rin kng tama
Post by Lenaren on Tue Dec 17, 2013 8:30 pm
thanks sis... 1+ din sa iyo... pag-aralan ko muna mapa nito...
Post by DJFEL on Wed Dec 18, 2013 7:25 pm
hmm...ano apdit na neto..
Post by Lenaren on Fri Dec 20, 2013 4:25 pm
....eto po some reading...
b+ - 110V
Vert IC input pin - 24V
Yoke - 24V, 24V
..na-observe ko master, pag pinatay ko ung unit may maliwanag na horizontal line na nalabas sa screen...
..posible din po ba na FBT na to?... halos nabalutan na kasi ng electrical tape ung FBT nya..
Post by Hertz on Sat Dec 21, 2013 12:55 pm
may leak ang flyback. palitan mo na lang para makasiguro ka
Post by DJFEL on Sat Dec 21, 2013 9:07 pm
normal ba b+ neto 110 lang yata..
Post by kaholito on Thu Dec 26, 2013 9:44 pm
ano po kaya ang dapat na output voltage dapat nito?
Post by Hertz on Sat Dec 28, 2013 3:18 pm
Lenaren wrote:....eto po some reading...
b+ - 110V
Yoke - 24V, 24V
ngayon ko lang napansin. masyadong palang mataas ang input mo [pin4].
kaholito wrote:ano po kaya ang dapat na output voltage dapat nito?
nasa 24 yan pag hindi tinanggal ang yoke
Post by Lenaren on Sun Dec 29, 2013 6:29 am
ta8403 k ang vert ic nito.....
ano po input pin nito master pin4 ba o pin7?....
thanks!
Post by Hertz on Sun Dec 29, 2013 5:57 pm
pin4 ang input.
pin2 ang output
pin6 ang supply
Post by ultrasonic™ on Fri Jan 03, 2014 6:22 pm
ayon my reference.. sundan mo lng ang diag ts....
Post by Oscar on Sat Jan 18, 2014 6:35 pm
baka may leak na ecap lang master
