HELP! Sanyo TV ST-21KF2V service data
Post by Lenaren on Fri Dec 13, 2013 6:54 am
Mga master patulong... may ni-repair akong tv... sira ang memory... pinalitan ko ng same memory kaso galing sa AC5-G board... nag-on naman kaso walang aidio, channel at video pick-up... kaya ba tong baguhin sa service mode lang o need talaga re-program ng memory?
... wala pa kasi akong programmer...
thanks!
Re: HELP! Sanyo TV ST-21KF2V service data
Post by Hertz on Mon Dec 16, 2013 1:43 pm
mas madali kong may exact model na mapagkunan.
subukan mong na ring i reset.
1.turn off your tv, plug the empty eeprom
2.turn tv ON, press and hold the TV / AV until CLR appears on the screen
3.press " F " / " MENU " on the panel to get back to normal mode
Post by Hertz on Mon Dec 16, 2013 1:47 pm
pag ayaw. subukan sa service mode. palitan ang mga item na may kinalaman sa audio at video process
Post by Lenaren on Mon Dec 16, 2013 3:34 pm
salamat po master hertz....
try ko po ito master....
1+ po sa iyo...
thanks
Post by ultrasonic™ on Tue Dec 17, 2013 12:32 pm
uu  sis pwde yang baguhin sa s.mode pero medjo madugo yan kasi daming hindi na support...  pero mas recommend ko na try mo pa ibang dump ng sanyo sis.. kng saan ang medjo matino.. ung ang gamitin mong reference at kalikutin pa ng kunti
Post by Lenaren on Wed Dec 18, 2013 5:35 pm
master wala po ba kayong service data nito? .... ung mga cpu debug date kailangan din po bang palitan?... na-try ko po kasing baguhin ung mga data patungkol sa audio and video but still no luck po.....
thanks!!
Post by Hertz on Sat Dec 21, 2013 12:50 pm
Service Description
RFAGC
- RF AGC Adj.
H-PHA - H-Phase (H-Centering) Adj. (50Hz)
V-POS - V-Position (V-Centering) Adj. (50Hz)Fixed.
V-SIZ - V-Size Adj. (50Hz)
V-SCO - V-S Correction (50Hz)
V-LIN - V-Linearity Adj. (50Hz)
H-P60 - H-PHASE Adj. (60Hz)
V-S60 - V-Size Adj. (60Hz)
OSDHP - OSD H-Position Adj.
OSDC - OSD Contrast Adj.
V-SCP - Correction of the V-size accompanying brightness change.
H-SCP - Correction of the H-size accompanying brightness change.
SBIAS - Sub Bias Adj. (Do not change)
RBIAS - Red Bias Adj.
GBIAS - Green Bias Adj.
BBIAS - Blue Bias Adj.
RDRIV - Red Drive Adj.
GDRIV - Green Drive Adj.
BDRIV - Blue Drive Adj.
1-LINE APPEAR - White Balance Adj.
DRV - White Balance Adj.
B-YD - B-Y DC level Adj.
R-YD - R-Y DC level Adj.
B-YDN - NTSC B-Y DC level Adj.
R-YDN - NTSC R-Y DC level Adj.
SBDC - SECAM B-Y DC level Adj.
SRDC - SECAM R-Y DC level Adj.
G-YA - G-Y angle Adj.
RBGB - R-Y, B-Y Gain Blance Adj. (Do not change.)
RBAG - R-Y, B-Y Angle Adj. (Do not change.)
G-YAN - NTSC G-Y Angle Adj.
RBGBN - NTSC R-Y, B-Y Gain Balance Adj.
RBAGN - NTSC G-Y, B-Y Angle Adj.
COGV - Coring Gain Adj.
BLKS - Setting of Black stretch start.
BLKG - Setting of Black stretch gain.
BRTA - On and off of ABL.
BRST - Setting of ABL.
BRTH - Setting of ABL.
WPL - White peak limitter.
YGAM - Y Gamma setting.
PORW - Switching of Pre-shoot and Over shoot in AV mode.
PORS - Pre-shoot/Over shoot Adj. in AV mode.
RFCO - RF Coring Gain Adj.
PORWN - Switching of RF Pre-shoot and Over shoot.
PORSN - RF Pre-shoot/Over shoot Adj.
TINT - RF Tint Adj.
TINT443 - NTSC 4.43 Tint Adj.
SHRF - RF Sharpness Adj.
TEXTC - OSD TEXT Contrast.
VOLUM - Volume Control Adj.
DEEM - De emphasis TC.
VIFSW - VIF System Switch.
SIFSW - SIF System Switch.
V-LVL - Video Level Adj.
FMLVL - FM Level Adj.
IFOM-S - Over Modulation Switch
IFMN-S - Audio Monitor Switch
IFTRAPS - SIF Trap Switch ON/OFF
IFMLVL - Video Level & Modulation
TRAP-T - Trap Test
H-FRQ - Horizontal Frequency
FBTS - FBT Blanking Switch
COOP - Color Killer Option
HBLKL - H-Blanking Control. (Left)
HBLKR - H-Blanking Control. (Right)
AFCRF - RF AFC gain & Gate Adj.
VSRF - RF Vert. Sync. Separation Adj.
CDMRF - RF Vert. Count-Down Circuit Adj.
AFCAV - AV AFC Gain & Gate Adj.
VSUAV - AV Vert Sync. Separation Adj.
CDMAV - AV Vert Count-Down Circuit Adj.
HLVDRF - H Lock, V Detect RF
HLVDAV - H Lock, V Detect AV
VCO-SW - C-VCO Adj. Switch
VCO-ADJ - C-VCO Adj.
CROSS-BW - Output Pattern Picture
AVNCON - AV Blue Back Signal Contrast
AVNBRI - AV Blue Back Signal Brightness
POMT - Power Mute Time Adj.
CHMT - Channel Change Mute time Agj.
SYST - The number of times that a colour system AUTO is judged.
S-STE -Stereo/Mono Option. 0=MONO, 1=SIMPLE AV STEREO, 2,3=AV STEREO
VOLTBL - Volume Table
MPP - Multi Personal Preference function on/off o=without M.P.P., 1=with M.P.P.
TUNER - Tuner Option
AV123 - AV1/AV2/AV3 Option, 0=AV only, 1=AV1, AV2, 2~3=AV1, AV2,AV3
OPT POS - Programme number Option, Position No. Option, 0=100 pos., 1=256 pos.
GAME - GAME Option, 0=without GAE, 1=with GAME
LANGUAGE - Language Option, 0=without Language, 1=with Language
OPT COL - Colour System Option, 0~1=PAL only, 2=VMT, 3=China/Indonesia, 4=3System,5~7=Multi
OPT SIF - SIF System Option
OPT BASS - Bass Expander Option, 0=without BASS, 1~2=BASS EXPANDER,3=WOOFER
OPT SURR - Surround Option, 0=without SURROUND, 1=with SURROUND
SUB-BT - Audio IC (NJW1142)Sub Bass Treble adj.
A-AGC -Audio IC (NJW1142) AGC adj.
R00 - ROM Correction
R01 - ROM Correction
R02 - ROM Correction
I
I
R72 - ROM Correction
Post by Hertz on Sat Dec 21, 2013 12:54 pm
@lenaren. sorry wala akong data. hindi ko rin alam ang chassis. baka makatulong ang description.
Post by DJFEL on Sat Dec 21, 2013 9:12 pm
sub mona...wla ren ako nito..
Post by ultrasonic™ on Thu Dec 26, 2013 8:22 pm
waaaaaa  omg
ang haba... +1 ky hertz ^_^
paabang na rin
Post by Lenaren on Sun Dec 29, 2013 6:25 am
Thanks ... 1+ master... salamat sa tiyaga.....
update ko n lng kyo nito.....
Post by Hertz on Sun Dec 29, 2013 6:00 pm
walang anuman
