what is OSD?
what is OSD?
Post by DJFEL on Sun Sep 22, 2013 3:40 pm
OSD
An on-screen display (OSD) is a control panel on a computer monitor or television screen that allows you to select viewing options and/or adjust components of the display, such as brightness, contrast, and horizontal and vertical positioning.
On a computer monitor, an on-screen display is usually activated by buttons on the bottom of the monitor. As an example, one button may bring up a display of the brightness and contrast levels, which may be adjusted by pressing the monitor's up or down arrow buttons.
On a television screen, an on-screen display can usually be activated either through buttons on the television set itself or through the remote control. Television on-screen displays are becoming increasingly complex and interactive. In addition to the visual calibration options, the on-screen display may allow you to view program information, search for programs, or put certain channels under parental control.
Re: what is OSD?
Post by Lenaren on Mon Sep 23, 2013 4:13 pm
pag walang OSD master... ano ang kalimitang pyesa ang may problema?
Re: what is OSD?
Post by DJFEL on Mon Sep 23, 2013 7:15 pm
wlang display lahat pang wla osd..patay yong heater esa dyan..
Re: what is OSD?
Post by ultrasonicâ„¢ on Tue Sep 24, 2013 2:42 pm
kng buo ang picture display at osd lng ang nawawala..
check nyu ang vertical at horizontal sync pulse
Re: what is OSD?
Post by james on Tue Sep 24, 2013 3:05 pm
Basa ng matuto dito.
Re: what is OSD?
Post by Oscar on Tue Oct 01, 2013 5:37 pm
pwede rin kaya na ang crystal ang sira master?
Re: what is OSD?
Post by Lenaren on Fri Oct 04, 2013 4:37 pm
paano po pag-check ang vertical at horizontal pulse master... sensya na... di ko pa alam eh...
Re: what is OSD?
Post by Electro on Sat Oct 12, 2013 3:03 pm
gagamit yata ng scope. tama ba master?
Re: what is OSD?
Post by DJFEL on Sat Jul 19, 2014 10:23 am
yaps tama...my ron ring eba pa ano mang test horizontal puls...
Re: what is OSD?
Post by sherlanmamaril on Sat Sep 05, 2015 4:19 am
grabe ah panu po yung snyc pulses mababasa if wala akong scope???
Re: what is OSD?
Post by Hertz on Fri Sep 25, 2015 8:33 am
gamit na lang ng frequency counter kong walang oscilloscope
Re: what is OSD?
Post by sherlanmamaril on Fri Sep 25, 2015 8:33 pm
wala din akong counter master mutimeter lang po . paanu kaya ehhe mahirap pala pag walang countr or scope san ang test points po nyan master at anu nasisira na madalas po ? jungel ?
Re: what is OSD?
Post by Hertz on Wed Sep 30, 2015 1:26 pm
Kong DMM iyang sayo at may Hz settings ay puede yan.
Re: what is OSD?
Post by Hertz on Wed Sep 30, 2015 1:30 pm
marami ang dahilan kong bakit walang osd. puede walang binabatong osd out ang system patungong jungle. puede rin naman tumatanggap ng signal ang jungle pero hindi naman nagbibigay ng composed osd outs. puede rin may problema ang quartz o crystal niya
Re: what is OSD?
Post by sherlanmamaril on Sat Oct 03, 2015 11:40 pm
master anu po value ng crystal ng system? sensdya po busy kais ako sa jvc ko hirap po kasi ako sana magawa kona po
salamat po pala sa pag entertain sakin dito sa forum po at natutuwa po ako dun
Re: what is OSD?
Post by alvinquimbo on Wed Oct 07, 2015 11:07 pm
sis kung sa system ang tinutukoy mo ay nasa 8mhz yata yan, kasi sa pagkakaalala ko ang crystal value sa chroma ay 3.8mhz...itama nyo po ako sir hertz kung mali ako...sana makatulong sis.. Very Happy Very Happy Very Happy
Re: what is OSD?
Post by Hertz on Sat Oct 10, 2015 4:49 pm
tama, pero may iilan na rin ngayon na gumagamit ng halos kapantay ng sound 4.5
Re: what is OSD?
Post by sherlanmamaril on Sun Oct 11, 2015 10:17 am
ahhh ganun pala po salamat po master anu steps niyong gagawin kung walang osd magayan naman po , kutob ko popokus kayu maicheck si system na sure na gumagana sya
Re: what is OSD?
Post by alvinquimbo on Sun Oct 11, 2015 6:56 pm
Sa akin sis,pwede mo itry ireprogram yung eeprom baka corrupted na..Sa ibang tech naman ay direct sub lang sila ng sytem ic or chroma ic nang makausad din sila..Nung may natrouble ako na ganito na walang OSD ay nagtry ako mag reflash ng eeprom pero no effect kaya pinalitan ko si UOC or Ultimate one chip nya at ayun naging ok sya. Ginagawa ko lang ito ang pag diect sub pagprovided na ok lahat ng mga supply na kelangan sis..hope na makatulong.. Very Happy Very Happy Very Happy
Re: what is OSD?
Post by Electro on Tue Oct 13, 2015 6:08 pm
tama si master, direct sub ng gumaganang ic
Re: what is OSD?
Post by sherlanmamaril on Tue Oct 13, 2015 6:19 pm
maganda nga pong idea iyon , nd ako makatutol naisip kopo pag direct sub eh open pala voltage wala din kahit magpalit ok salamat po ang luamng tv pa naman nila ang mahal ng jungle
pa ot po san po makakabiling programmer ?magkano po yun?
Re: what is OSD?
Post by Hertz on Wed Oct 14, 2015 10:18 am
sina Sir kasamiko at Sir Noman ay may binibintang ganyan. pm mo sila
Re: what is OSD?
Post by sherlanmamaril on Wed Oct 14, 2015 1:53 pm
ok salamat po
Re: what is OSD?
Post by sherlanmamaril on Sun Dec 13, 2015 2:59 pm
master osd troubleshooting pa po , anu pa po tips niyo dito?
Re: what is OSD?
