139B+ normal ba sa kolin kc-20Mkp11 need mapa
Post by xxxvirus1987xxxx on Sat Aug 17, 2013 11:53 am
hot:d1514
reg:3s0680rf
system:s3c8837d38-aqb7
jungle:s1h2163c01-aq
memory:24c0
fbt pin.
.col
.b+
.180
.grnd
.24
.12
grnd
abl
heater
nc
bago poh fbt nito kahit walang fbt kalas laht nasa 139 b+ nya...
may 5volts sa pin 8 in memory nagkakaroon ng 8.something sa hvcc ng jungle during power on nwawala yung led indicator indication na nagpower on na may oscillation poh 5vols ac sa base ng hot....
kaso bakit kaya walang 12volts at 24volts galing ng fbt....wala din heater at screen psu poh kaya to anu kaya normal b+ nito?
any mapa poh?kasi yung hot nya ay d1554 yan ba tlaga orig nyan hot galing din kasi sa ibang tech to parang kapos kasi yung paa nagdugtong na lang ako ibig sabihin di ito yung orig na hot nya?
xxxvirus1987xxxx
Re: 139B+ normal ba sa kolin kc-20Mkp11 need mapa
Post by kchrysz15 on Sun Aug 18, 2013 8:58 am
sis check capacitor 160v/100uf baka open n sya, kaya mataas n ung B+ punta FBT, check u rin lahat pyesa
kchrysz15
Post by kchrysz15 on Sun Aug 18, 2013 9:00 am
sis wat nga pala model# en chassis # nian
kchrysz15
Post by xxxvirus1987xxxx on Tue Aug 20, 2013 9:51 am
pinalitan ko na lahta ng parats sa power suply nito....anu pa ba dahilan kung bakit matass ang b+ nito...
xxxvirus1987xxxx
Post by xxxvirus1987xxxx on Tue Aug 20, 2013 9:52 am
mga hgwebes if makukuha ko chasssis post ko poh...kahit di nakakabit fbt 139prin....tyagaan ko nga mga resistor nito.....palitan ko laht update ko kayo mga master...
xxxvirus1987xxxx
Post by Hertz on Tue Aug 20, 2013 6:17 pm
check mo ang feedback circuit baka may nag change value na resistor
Post by kchrysz15 on Wed Aug 21, 2013 8:22 am
d2 lang kmi waiting:D waiting
kchrysz15
Post by arkin on Wed Aug 21, 2013 7:37 pm
nasusunog ba h.out nyan?kong hindi normal lng cguro yan on standby mode..
Post by xxxvirus1987xxxx on Thu Aug 22, 2013 9:55 am
di ako sigurado sa b+ nito kung 139 talga peru pinalitan ko na lahta ng parts sa psu nito maliban sa mga mylar at ceramic resistor pinalitan ko na reg,photo coipler at tl431 bumaba ng kunti nasa 134b+ na
xxxvirus1987xxxx
Post by xxxvirus1987xxxx on Thu Aug 22, 2013 10:02 am
Sana may mapa nito dalawa na kasi nasira nitong hot okey naman sial parihas yung lumang fbt kasi singaw lang using fbt tester okey nman sila parihas magkaiba nga lang ng amp yung bago at luma ibig sabihin mataas tlaga b+ nito kaso
Pinalitan ko na to
Regulator,
Photocoupler
Tl431 at lahat ng mga resistor sa feedback section 4X ko ng tinest using digilta at anlog tester
Filter ng secondary palit narin 47/160 at 100uf/160
xxxvirus1987xxxx
Post by Electro on Fri Aug 30, 2013 4:34 pm
ang alam ko master xxxvirus1987xxxx. sirain ang flyback ng Mkp11. master pareho lang ba sila sa 110 ?
