Ano po ang pinagkaiba ng Active component sa Passive Component ? 5 5 2
Post by volter on Sat Aug 28, 2010 4:20 pm
Posted by Dizon on June 4, 2010 at 6:26pm
mga sir nalilito kasi ako kong ano ba talaga pinag iba nila
salamat po sa mga mag reply
volter
Re: Ano po ang pinagkaiba ng Active component sa Passive Component ?
Post by volter on Sat Aug 28, 2010 4:37 pm
Reply by mayalin143 on June 5, 2010 at 9:46am
AcTive cOmpOnEnt is wHEn thEre's a tRansFer of rEsistAnce bEtweEn iNput aNd ouTput frOm LOW to HIGH or ViCe vErSa...
PasSsivE cOmpOnEnt iS wHEn iT dOes noT poSsEss a pRopErty of tRansResiStaNce...
Reply by Piezo on June 5, 2010 at 1:43pm
ACTIVE components increase the power of a signal and must be supplied with the signal and a source of power.
Examples are bipolar transistors, field effect transistors etc.
The signal is fed into one connection of the active device and the amplified version taken from another connection.
In a transistor, the signal can be applied to the base connection and the amplified version taken from the collector.
The source of power is usually a dc voltage from a battery or power supply.
PASSIVE components do not increase the power of a signal.
They often cause power to be lost.
Some can increase the voltage at the expense of current, so overall there is a loss of power.
Resistors, capacitors, inductors and diodes are examples of passive components.
Integrated circuits contain both active and passive components.
Since they usually increase the power of a signal and require a source of dc power they are treated as active devices.
Reply by ultrasonicâ„¢ on June 11, 2010 at 9:24pm
para mas dali sabton
passive component is an electronic component that does not require a source of energy to perform its intended function. in short mga electronic parts na dli na knahanglan ug proper biasing to do their function.
ex: resistor, capacitor & inductors
same with active component vice versa lng sa passive compo
An active component is a visual works component whose widget is a view and has a Model and a Controller.
need nya ng proper biasing.. exact voltage & current specially in termz of applying polarity to saturate..
ex. mga semiconductor device gaya ng diode, transistor, thyristor family, ics & etc...
@TS hope na getz nyu (^_^
Reply by Dizon on June 22, 2010 at 3:35pm
maraming salamat sa po inyo, naiintindihan ko na..
pagnangangailangan siya ng kuryente at voltahe para gumana - Active Component po siya
pag hindi nangangailangan ng kuryente at voltahe - Passive Component po siya
volter
